Old 09-02-2013, 12:44 PM   #1
ayousef
ayousef's Avatar
Drives: 2013 ZL1
1000rwhp fuel systems?
well im wondering what are the high horsepower STREET guys using on their cars, im asking because I have an Aeromotive Eliminator with the pump speed controller which sounds like morse code when it changes the pumps duty cycle but on to my disappointment my car actually vaporlocks for lack of a better word after say a 30minute drive. Fuel pressure starts dropping, pump gets louder fuel trims go positive until they get as high as 20%+ correction or 25%+ cant remember then the motor takes a dump.
I have the pump speed as low as possible at low rpms but this didn't cure my problem. Aeromotive recommended I run a fuel cooler on the return line and use a larger return a -8 instead of the current -6.
So im wondering what are you guys using and did anyone ever face a vapor lock issue driving on the street?
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 09-02-2013, 12:49 PM   #2
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Squash Return System... Put it in and forget about it.
No vapor lock issues, no pressure drop issues, no need for a speed controller.
Matt @ FSP is offline   Reply With Quote
Old 09-02-2013, 01:02 PM   #3
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
I got the triple pumper system from Lonnie's performance but now that Squash is out I would go with them. Andy is very knowledgeable and has a great product and customer service. I have been using his stuff on other builds.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 09-02-2013, 01:21 PM   #4
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
+1 for Squash Dual fuel pumps system for the Camaro. I just installed mine with the car on jack stands. Nice kit options. You can hear it running but its really quiet compared to what I have ran in my drag car.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 09-02-2013, 02:28 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Squash. Andy's setup has been proven over 1k rwhp.
Old 09-02-2013, 03:54 PM   #6
Boost6924
Drives: 2SS/RS
I run Aeromotive Eliminator in tank pump without speed controller.
After fixing stock tank vent issue with that pump, it can support around 1050RWHP with pump gas in my application, put is right on the edge and looses couple of pounds of fuel pressure at high rpm's.
1100RWHP level pump is clearly out of juice. Also need to keep the tank at least 1/2 full all the time.
Has anybody maxed out the squash system yet? I'm thinking of making sump tank with Weldon pump and have aeromotive to pump in It. I hate to put fuel cell in my trunk, i'd like to keep it stock looking. When I upgrade my fuel system, it needs to support 1800-2000 off the crank.
438cid IPS Twin Turbo.
Boost6924 is offline   Reply With Quote
Old 09-02-2013, 04:02 PM   #7
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Squash
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons)
2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 09-02-2013, 04:02 PM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I have this set up without a tank in the trunk.... We cut out the wheel well and plated over it. We use the space in the trunk for the parachute frame, and built a frame in the space left over for a sump. I run the Lingenfelters into the sump and then the Weldon pulls from the sump.... I've yet to run into any fuel issues... We moved the battery up into the trunk and forward.... It works well and leaves tons of room for the dual 15 lb nitrous bottles...
Old 09-02-2013, 04:20 PM   #9
blake-b
blake-b's Avatar
Drives: 2009 ZR1
If you use the Squash 450lph pumps (e85 version) with gasoline, I think they will support ~1500rwhp. tmayer made almost 1400rwhp with the e85 pumps on e85 (at least I think he was running e85) with his 1LE.
Old 09-02-2013, 09:42 PM   #10
ayousef
ayousef's Avatar
Drives: 2013 ZL1
this doesn't sound right are you running a return? or do you have the regulator BEFORE the rails? Also im expecting the regulator is boost referenced and if so what is your base fuel pressure?
Old 09-02-2013, 09:44 PM   #11
ayousef
ayousef's Avatar
Drives: 2013 ZL1
im wondering why wouldn't it vaporlock, the reason im asking is because im running the aeromotive at a very low duty cycle at low rpms and even a cruise on the highway without using the pump at high DC will still cause the fuel system to vaporlock, im hoping a fuel cooler solves the issue since im trying not to change my entire setup.
I was always against dual pump setups which is why I went with a big single.
Old 09-02-2013, 09:48 PM   #12
ayousef
ayousef's Avatar
Drives: 2013 ZL1
guys how good is the Weldon big pump compared to the eliminator? noise levels, reliability and such?
Old 09-02-2013, 09:55 PM   #13
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Noise is slightly better, not much, but it works for me... My aero motive big boy only lasted six or seven hours of total run time, with the FPC. No problems with the Weldon.. Note...me hop carefully for the one rated for continuous use... With the design we use, of the sump dumping back to tank, I've had no overheating issues... Drove it seven hours one way and back...
Old 09-02-2013, 09:59 PM   #14
Jordan I
Mil-spec wiring/elec!
Drives: LSx swapped FD RX7, '02 Duramax
Send a message via AIM to Jordan I
There are a few people running around with multiple Walbro's 400+lph in-tanks now (I think you can fit three in the stock Camaro hat, which is a retarded amount of fuel) and they're not a bad way to go.
If you wanted to stay single, Fuelab's got a new setup (190gph, 1800hp crank) that I'm running in our 415ci YSi LSA (e85). The pumps have a speed controller built in, and the regulator has a pressure transducer built into the return side - start bypassing a ton of fuel, slows the pump down (without sounding like Morse code haha), and when you stomp it the return side closes and steps up the pump duty. Very simple, very smooth, and idiot-proof - if there's a problem, it defaults to full speed. I'm running a Bosch 044 to feed a surge tank, but Fuelab has all the mounts and a 'sock'-type filter to run it in-tank if you want for a truly 'stock'-like install.
Food for thought. The Weldon's will be noisier than the Eliminator (especially if your Eliminator is in-tank right now), but are very reliable.
Jordan I is offline   Reply With Quote
