07-14-2014, 11:01 AM | #1 |
Weird noise from the driver side
I got this weird noise from the driver side that sounds like something's tapping rapidly on the metal surface, the noise only come on when I'm driving on highway up to around 70 mph, I don't hear it when driving locally or at a slower speed, took it to the dealer today, a senior technician went on a ride with me, and he heard the noise too, but later on told me he thought he heard something at a time , but it turned out they couldn't find the source of the noise , and told me to come back when situation gets worse, then might be easier to identify, but the noise is killing me, I have to turn on the music just to pretend that I'm not hearing it, any one here might know something about it?
07-14-2014, 11:07 AM | #2 |
Drives: 2011 1LT Join Date: Mar 2012
No joke: I experienced a similar issue. Drove me frickin' bonkers. Turned out to be the little plastic cover on top of the seat belt anchor... it had popped off, was dangling by its little tether. Took .58 seconds to fix, once identified.
07-14-2014, 11:07 AM | #3 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
I would guess a loose heatshield or piece of plastic underneath flapping in the wind. Possible a inner fender lining or something as well. If that's the case you should be able to just check for any loose plastic panels and such. Go around tapping on the inner fenders and check underneath for any loose plastic.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
07-14-2014, 12:02 PM | #4 |
The dealer said they didn't find any lose debris or object in it, I tried tapping on the inner fenders and sounds solid
07-14-2014, 01:03 PM | #5 |
Drives: 2012 1LS V6 LFX Join Date: Jun 2014
check the tires for a screw? I had that, the screw didn't go deep enough to cause a leak but it was noise as all get out when you were doing highway speeds
07-14-2014, 01:06 PM | #6 | |
I checked, no screws, the noise is coming from the driver side between the door and the dash Sent from my iPhone using Tapatalk |
07-16-2014, 07:37 PM | #7 |
Nobody knows what happened?
