01-02-2024, 12:47 PM | #1 |
Drives: 2019 ZL1 A10, Orange Crush Join Date: Jul 2009
ZL1 Squirrely-ness consensus?
I have a 2019 ZL1 auto that has the squirrely-ness problem. The previous owner attempted to fix it by replacing the tires with Nittos all around, but it is still very scary to drive. I had it aligned by a guy who has done race alignments for almost 40 years, and he said he'd never seen a car behave that way in his life, and he's seen a lot. He aligned it to what he thought would help but it is still a dangerous car, even at part throttle. He owns a 427-powered 69 Camaro and he said my ZL1 is the only car he's ever really been afraid of.
I looked over some of the forum posts about this and they all appear to be from 2018 or similar-aged...the only answer I could really get out of it was to replace the rear bushings with solids. My question is, has anyone else fixed their ZL1's squirrely-ness with something other than bushings or alignment? I'm at a loss as to what could be causing such a terrible condition. |
01-02-2024, 12:53 PM | #2 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
So many things to consider here. I guess the first questions are you sure the tires aren't breaking traction? What are the road conditions? What tires are on the car now and are they all set to correct tire pressure? Was it aligned to factory specs? I think the BMR rear cradle lockout would certainly help but I suspect you've got other issues at play.
01-02-2024, 01:23 PM | #3 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
You said he aligned it to what he thought would help. Can you post the alignment results before and after? It could also still be related to tires.
01-02-2024, 01:33 PM | #4 | |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I'm in Springfield so my car sees the same type of roads yours does. My 2020 ZLE felt like it was going to lose control every time I got on it when it was new. Come to find out, the car would not align to factory specs with the factory rear suspension bars. I ordered all the BMR rear suspension bars and had it aligned and it completely changed the car. It doesnt feel like its getting out of hand now even when its rolling the tires at over 30MPH. |
01-02-2024, 01:53 PM | #5 |
Currently it has Nitto NT555G2s on it. All four tires are at 32psi, but I've tried everything from 26 to 40, and variations on the front and back both ways. I don't know what he aligned it to, but he said the rear toe was off quite a bit. He tried changing the alignment several times over the span of a week and nothing seemed to help the condition. If it's breaking loose it's doing so at less than 1/4 throttle. Usually when I pull out to pass someone is when it presents itself most severely; as soon as I put my foot down (less than 1/4 throttle even) it acts like the rear end is very loose. He noted the same condition and suspected maybe it was something with the electronic differential, but to my knowledge, there's no way to fix that, is there? I have tried driving with all of the electronic gewgaws on and with them off; I've tried it in every drive mode and it's just the same.
I'm willing to put new stuff on the back end if it will fix it...can you tell me exactly the BMR parts you put on it? Thanks for everyone's input! This is definitely the best car I've ever owned, but with one little flaw that might kill me! |
01-02-2024, 02:11 PM | #6 |
Take a look on their site for Bushing kits. It depends on how much NVH you’re willing to tolerate, but the Lockout kit should fix the problem. You could also install the 1LE factory kit, but it’s more work.
I’d do a search and look for posts on this problem. There’s lots of good info in this forum. |
01-02-2024, 02:14 PM | #7 |
Thank you, I'll try that.
I've looked all over the site but it seemed like every post was from years ago; I thought maybe I was missing a fix somewhere that everyone had implemented. I'll report back once I get the bushings installed. Thank you again for all of the input. |
01-02-2024, 02:17 PM | #8 | |
01-02-2024, 02:27 PM | #9 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
^^This, did the whole swap in my garage on jack stands. Completely changed the way the rear felt under load at high speeds.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
01-02-2024, 03:33 PM | #10 | |
For some people, the poly style bushings might be a better fit but then you dont get the on car adjust ability. As others suggested, I'd start with the cradle lock out kit on a ZL1. My 1LE already had the solid bushings from the factory so I knew that wasnt my problem. I did drive a regular ZL1 with a 6spd a few months back and immediately noticed how loose the rear cradle felt compared to my car. |
01-02-2024, 05:31 PM | #11 |
Drives: 2021 ZL1 1LE with PDR Join Date: Oct 2022
My ZLE was scary at full throttle, then I got a good alignment and it just squats and runs. The alignment was all over the place beforehand.
Have it tripple checked. |
01-02-2024, 06:57 PM | #12 |
Drives: 2016 2SS Convertible Join Date: May 2012
01-03-2024, 06:44 AM | #13 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
BMR Cradle lockout, like the others have said, will take out most of that loose feeling on the rear under power. Of course alignment is a thing, tires are a thing, but the cradle lockout is where you're going to find the answer.
01-03-2024, 11:38 AM | #14 |
Drives: Chevrolet Camaro ZL1 Join Date: Sep 2019
Every time I experience the issue you are talking about in my car, I take it in for an alignment. The alignment helps, but I think the lockout kit is the ultimate answer. I intend to get that and install it at some point in the future.
