#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction Discussions
BeckyD @ James Martin Chevy
Old 04-18-2018, 04:05 PM   #1
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Does the AC shutoff @ WOT?
Naturally who would be running the AC anyway when you wanna go fast but here in Florida you get into the habit of just having the AC on Auto and forget about it. I was just curious if our AC Shuts off at WOT anyway so it didn't really matter. I loaded the stock tune on our car into HP Tuners and found this screenshot that I found on the corvette forum. They seemed to be in the dark about it as well. Does this mean our AC does NOT turn off at WOT?
Former Ride: 17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Baro Breakout Harness | LT4 Map Sensor | Katech Ported TB | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
Dysan911 is offline   Reply With Quote
Old 04-18-2018, 04:37 PM   #2
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Good question. For those of us interested in adding an intercooler chiller, we need to understand what's going on here.
Atomic Ed is offline   Reply With Quote
Old 04-18-2018, 04:46 PM   #3
Dysan911
Dysan911's Avatar
This was looking to be a good conversation but it just sorta fizzled out.
https://forum.hptuners.com/showthrea...sable-Settings
Old 04-18-2018, 04:55 PM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I believe it does.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 04-18-2018, 07:39 PM   #5
GT-ER
Drives: 2018 Camaro ZL1
I haven't looked at my compressor, but if it's a variable compressor then it might not even have a clutch to disengage (some do, some don't). All it does it change the rate of compression based on pressure readings from sensors as the RPM's go up.
GT-ER is offline   Reply With Quote
Old 04-18-2018, 07:45 PM   #6
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
I’m pretty sure it does turn off.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 04-18-2018, 07:57 PM   #7
Wierd Harold
Drives: 2017 2lt rs
It should cycle off and on according to high and low side pressures in the system.
Wierd Harold is offline   Reply With Quote
Old 04-19-2018, 12:52 PM   #8
Dysan911
Dysan911's Avatar
I hear ya fellas but man I can definitely feel a difference doing a quick WOT with AC on and with it off. It just loses that snappiness and stronger pull with it on. Even the guys on the vette forum who were logging with HPTuners said they never saw the AC parameter show OFF. It always stays ON until you turn off the AC manually with the switch.
Old 04-19-2018, 07:23 PM   #9
Daves1SS
Daves1SS's Avatar
Drives: 2016 Camaro 1SS
I’m pretty sure it turns off, but sure would be nice to have confirmation of that. I’ll tell you one thing though, in the summer time, at least with the Edelbrock kit, the car nearly feels naturally aspirated when it’s hot out and the IAT’s are over 130. Their tune really dials timing back hard after 130 degrees. That’s why I freaking love this killer chiller. The car is still a beast in 90-100 degree temps and the AC blasting.
Sorry to jump off topic there somewhat. I don’t stay in it long enough at WOT to notice if the air coming from the vents is warmer or not. I would think that would be a pretty easy way to figure it out wouldn’t it? Do it on a real hot day and stay WOT for a decent amount of time with the fan on high and the AC pumping?
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous:
'12 Mustang GT 6MT (12.47 @ 115.88)
'09 G8 GT (11.86 @ 120.47)
'05 GTO 6MT (slow, lol)
'01 Grand Prix GTP converted to turbo, high 11's
Daves1SS is offline   Reply With Quote
Old 04-19-2018, 07:42 PM   #10
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
All compressors have an internal or external clutch. Here is capture from CTS V2 they turn off at WOT and 3800. No idea what is going on with the 7000rpm, I run a temporary LED from the clutch relay and watch the LED turn off to verify.
TrekGTO is offline   Reply With Quote
Old 04-19-2018, 08:57 PM   #11
GT-ER
Not true. Sanden for example has variable displacement compressors that do not have any kind of clutch mechanisms internal or external.
Old 04-20-2018, 09:18 AM   #12
TrekGTO
TrekGTO's Avatar
What model Sanden?
Old 04-20-2018, 08:57 PM   #13
GT-ER
What model Sanden?
http://sanden.com/pistoncompressors.html
I've actually disassembled these before. The only electronic component is the pressure valve and sometime they fail.
Old 04-20-2018, 09:28 PM   #14
TrekGTO
TrekGTO's Avatar
Pulse width modulation is the internal clutch, which is how they have 0 output with no external clutch. Having done VW service for 35yrs this function is the leading cause for replacement. Car comes in with 0 compressor function at any rpm. I have yet to see a compressor with no clutch function but I am 2 yrs behind. SS Sedan has pulse width modulation and an external clutch.
