#Camaro6
Old 09-03-2018, 10:19 PM   #1
Razor427
Drives: 2016 Camaro 1SS
Fans on heat exchanger
Anyone install fans on there stock heat exchanger? I doing the LT4 conversion and plan on installing a pair of 8” spal fans...
Ray
Razor427 is offline   Reply With Quote
Old 09-04-2018, 10:58 AM   #2
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 20 X3M CP & 19 ZL1 1LE A10
I don’t know if these are needed like back in 03/04 with the Cobra. This car flows air pretty well on the 1000 coolers it has.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 09-04-2018, 11:01 AM   #3
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
For drag racing? Maybe. Not need for real track use.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 09-04-2018, 08:07 PM   #4
Razor427
Drag racing, car will never see a road course.
Ray
Old 09-05-2018, 06:05 AM   #5
Biscuit.fr
Drives: Red hot ZL1 A10 2017
If you want to put a fan,
I think the best will be on the horizontal radiator for the trans...
It will generate a flow and prevent trans overheat issue went racing behind another car
Biscuit.fr is offline   Reply With Quote
Old 09-05-2018, 09:59 AM   #6
Sakudog
Sakudog's Avatar
I'd think about a Alchol/Water sprayer for the coolers if it was just for Drag Racing. In all honestly, thought about designing something for Road Racing but never can get to it.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 09-05-2018, 10:17 AM   #7
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
You can also take a Look at the Weapon-x boost chiller!
Intimidator is offline   Reply With Quote
Old 09-09-2018, 03:07 PM   #8
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
If you are doing a conversion, skip the HX and go direct to Active Interchiller
TrekGTO is offline   Reply With Quote
