07-16-2011, 08:52 PM | #1 |
Drives: 2010 2ss/rs M6 Join Date: Nov 2010
Trans shot at 2099 miles???
Myself, wife and kids were coming home from a cruise night last night. I took off from a light, shifted 1-2 and got on it in second, shifted 2-3 and it grinded and wouldn't go into gear. Let it roll in neutral for a few seconds pushed the clutch in and the shifter was stuck in neutral. It would not go into ANY gear. Onstar sent a flat bed and now it's at the dealer. I'm a bit dissapointed that a car with 2099 miles had this happen. My only mods are a roto fab cai and an axle back so I'm hoping this will be taken care of quickly and correctly.
07-18-2011, 12:23 AM | #2 |
My trans line broke when I have around 200 miles on it- my airflow censor melted when I had 6 miles on it - that's my camaro
07-18-2011, 02:53 PM | #3 |
My 2010 had a transmission replacement with 3,137 miles. Your mods would have zero effect on the transmission problem you describe.
07-18-2011, 03:03 PM | #4 |
How long did it take them and how is it now? I'm assuming a gm rep is going to get involved which will add to the time the car is gonna be at the dealer.
07-21-2011, 01:37 PM | #5 |
Monarch is here
Drives: 2011 Summit IOM 2SS RS M6 Join Date: Jun 2011
This same thing happened to me last week. 1-2-wouldn't go into 3. So I did the same thing and threw it into neutral and coasted. I tried again and was able to put it into 4th and continue along. No problems since. I also have Skip Shift eliminator installed.
07-21-2011, 03:24 PM | #6 |
Left the dealer went about 1/2 mile and took it back. It shifts fine throughout the gears but the shifter itself now has a ton of play in it. Neutral has more play then before and when it's in gear it feels like it's in neutral. All of the SS camaros on the lot are automatics so I have nothing to compare it to. They got the service manager involved and they're gonna keep it until it's right. This sucks......
Similar Threads | ||||
PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
What can be killing my transmissions??? 7.7k miles and tranny number 2 is shot? | Arachnyd | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 5 | 04-29-2010 08:18 PM |
Is GM-4718M oil a farce if dino oil is used and is changed every 3,000 miles? | Hicompression | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 18 | 11-04-2009 10:48 PM |
Submit your best photo for a shot at the Showcase position at PFYC! | Redshift | Off-topic Discussions | 7 | 09-24-2009 09:10 AM |
Kevin Morgan Concept TA Unveiled | nUcLeArEnVoY | General Automotive + Other Cars Discussion | 66 | 09-07-2009 08:33 AM |
