#Camaro6
AWE Tuning
Old 11-12-2014, 02:13 PM   #1
Autonaut
Drives: El camino
2016 Camaro weight speculation
Well.. Sort of.
ATS-V weight has been publicised at 3600lbs.
Check the link
http://jalopnik.com/the-2015-cadilla...and-1657355253
If the ATS-V is a twin turbo V6 with all possible luxuries, what will a stripper LT1 camaro weigh?
This is my first post here. I've been following the camaro since camaro5.com more or less. I registered because i could not believe why no one had brought this fairly new info up yet?
Please, discuss
Autonaut is offline   Reply With Quote
Old 11-12-2014, 02:34 PM   #2
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Not sure about that link as I can't get it to work, but it could be the same as this
http://wot.motortrend.com/1411_leake...d_in_full.html
we get a "daily" automotive news here at work since we are automotove supplier to Camaro/GM and this is one came through today.
oneredry is offline   Reply With Quote
Old 11-12-2014, 02:37 PM   #3
MikeT
Drives: 2008 Malibu V6
Although the weight of the ATS-V is interesting, I don't think that we can draw any definitive conclusions about the weight of the new Camaro.
MikeT is offline   Reply With Quote
Old 11-12-2014, 03:14 PM   #4
Autonaut
Drives: El camino
The link is working here!
No, we cant draw any conclusions. But this the ATS-V is the same platform. It's a fully loaded twin turbo v6 most likely used as a test ground of some sort for the camaro. If a fully loaded ATS-V weighs 3600lbs, and a base model weighing in at 3350, dont you find it likely that the new camaro will weigh no more than 3600lbs in v8 trim?
If not please enlighten me.
Old 11-12-2014, 03:43 PM   #5
Iroc_Z28
Iroc_Z28's Avatar
Drives: 2017 1SS 1LE
3600 lbs sounds like a decent estimate. I personally think the v8 camaro will come in a bit heavier, I'm guessing a tad under 3700 lbs.
And on a side note, the ATS V is shaping up to be a mighty fine car, and the GT3 spec race car is looking pretty nasty.
http://www.racer.com/pwc/item/108174...677703821217_n
Iroc_Z28 is offline   Reply With Quote
Old 11-12-2014, 04:09 PM   #6
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
I agree that it will likely be around 3,700 lbs. I'm sure they will put beefier drivetrain in it. However it does make you wonder about the net weight difference between the engines. The LS series of engine is light for what it is and I believe the LT1 weigh's like 30lbs more than the LS3. With the LF3 being DOHC and has turbo + plumbing I'm willing to wager it is close to being a wash.
If the 6th gen. SS comes out weighing <3700 lbs I will be delightfully surprised.
BaylorCamaro is offline   Reply With Quote
Old 11-12-2014, 04:29 PM   #7
Autonaut
Drives: El camino
DOHC, turbo, piping, intercooler and what not.. A LT1 camaro sporting the same horespower as the ATS-V, should be lighter. Im thinking the caddy also is heavier due to is being more luxurious.
If they dont succeed in making it lighter than the already relatively light ATS-V, i'll consider it as a fail.
Also.. If they cant get it lighter with a v8, how do they plan on handling the ecoboost 2.3l mustang with a 2.0liter down on horsepower?
Old 11-12-2014, 04:45 PM   #8
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
wow, what a let down of a thread. more speculation. *sigh*
Old 11-12-2014, 05:01 PM   #9
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
not even sort of....
title is bogus. good ol' bait n switch
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@DemonWorksPerformance
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 11-12-2014, 05:29 PM   #10
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Drives: 2023 GMC Canyon, 2020 Colorado
Seriously, the title needs to be changed. It's still pure speculation.
2023 GMC Canyon Elevation
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
Old 11-12-2014, 06:26 PM   #11
hypercarfanatic
hypercarfanatic's Avatar
Drives: 2013 F-150
Agree with this^
Originally Posted by Spartan01 View Post
I bet the comments were all written by a bunch of pseudo-intellectual, vegan, fedora-wearing, patchouli stinking, Prius driving, neo progressive, hipster frauds...
hypercarfanatic is offline   Reply With Quote
Old 11-12-2014, 08:28 PM   #12
Number 3
Hail to the King baby!
Number 3's Avatar
The CTS V-Sport is also off of the Alpha platform and also has the 3.6L TT engine and weights in around 4,000 pounds.
What we don't know is how much high dollar low mass hardware was involved to get a 3,600 pound ATS-V. Might be some CF in the hood for example that you won't see in a Camaro or at least at mid level SS Camaro.
Gives an idea of what might be but what will be is anyone's guess.
Old 11-12-2014, 08:38 PM   #13
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
If the 2.0L ATS coupe is weighing in around 3450 lbs and the V6 at 3560 lbs,
I don't see how a V8 Camaro on the same platform is going to lose much weight from where the 5th gen is now. The V8 engine, the transmission, rear end, brakes, cooling all adds weight.
CamaroTom is offline   Reply With Quote
Old 11-12-2014, 10:08 PM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by Autonaut View Post
Well.. Sort of.
Check the link
Please, discuss
Adding luxury usually adds weight. But cutting weight usually costs money. The question is, which plays a bigger role: features or cost? And keep in mind, a lot of what used to be considered luxury is now standard.
You might have to define 'much weight' here. Because to me, that implies less than about 50 lbs and I don't see that happening. The V6 ATS is about 200 lbs lighter than the current V6 Camaro. I can't see the 6th gen Camaro adding back 150 lbs
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
