02-25-2014, 10:31 PM | #1 |
Drives: 2013 zl1 Join Date: Sep 2013
Cam question
Im tring to figure out a cam that can give me the best power, and sound at idle, without the need of changing my stock converter. Im currently running headers no cats with 2.55 upper pulley , intake, and 100 shot. Any good suggestions?
02-26-2014, 04:48 AM | #2 |
Drives: 2013 silver ZL1 Join Date: Apr 2013
02-26-2014, 08:06 AM | #3 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
http://www.briantooleyracing.com/pos...-camshaft.html Is that your CTS-V?
Bryan 2018 ZL1 M6
02-26-2014, 01:17 PM | #4 |
No sir. That is the shop my car is currently at.
04-13-2014, 03:42 PM | #5 |
2015 Z28 Black #16 600rwhp N/A
Colorado speed and performance build: hand ported heads, titanium valves, hand ported throttle body,fast lsxr intake, custom cut lunati cam, lunati push rods, fm high performance lifters, dual beehive springs + titanium retainers, trunnions upgrade, ARH headers + x pipe, fast fuel rails, c5r timing chain, katech high volume oil pump, ati underdrive pulley, Taylor wires. Sold---2013 ZL1 M6 Silver Ice Metallic: 767 rwhp |
04-13-2014, 04:10 PM | #6 | |
Drives: 2018 ZL1 1LE Join Date: Sep 2013
Nickey Chicago Stage II cam. I personally love the idle and drivability is excellent. Even though I have a M6 he puts the same cam in both auto and manuals with no issue. Give Stefano a call at 630-377-1222 for more info. He's probably installed over 50 in Zl1's by now... Here's a quick clip. Wasn't fully warmed up so idle was just a touch high.
04-18-2014, 03:21 PM | #7 | ||
Drives: 2013 Camaro ZL1 bone stock 9K miles Join Date: Oct 2010
I think I'm going to look into that cam profile, do you have the specs? Love it. I'll be adding boost soon enough as well.
SLP- long tube headers, hi flow cats w/full SLP 3'' PowerFlo exhaust incl/X-pipe, 160 degree stat, SLP Blackwing CAI. Dyno tuned by ECS-407/409RWHP&TQ. BMR- trailing arms w/poly knuckle bushings, toe links, cradle bushings and differential bushings. QA1 rear lower control arms. Hurst short throw shifter, SS- level 4 axles, DSS- aluminum driveshaft, Pfadt- sport 1.5" rear sway-bar. SPOHN 1.25" front sway-bar. Monster LT1-S twin clutch. Prothane motor mounts. Best 1/4 mile so far- 12:70ET @ 112.24 MPH w/ 2.06 second 60'.
SOLD. |
04-18-2014, 07:02 PM | #8 |
Drives: 1973 Camaro Join Date: Jul 2011
BTR STG III in my junk.
Idles a bit like yours...not much lope. Don't care though as it makes good power.
73 Camaro, 6.0 LS, Billet S485, E85, 4L80E.
04-18-2014, 08:02 PM | #9 | |
04-19-2014, 01:13 AM | #10 | |
Thanks for the info, I will contact him soon when I decide what power level I want for a forced induction LS3. The right cam makes a Big difference. I'm just getting some idea's who has the best cam for my needs. Thanks again.
SOLD. |
05-11-2014, 06:47 PM | #11 |
I got the btr stage 3 and love it
05-11-2014, 10:35 PM | #12 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
05-12-2014, 07:48 AM | #13 |
Drives: 2014 zl1 triple black Join Date: May 2014
Just ordeed the BTR stage 3 will let ya know how it works
05-12-2014, 05:11 PM | #14 |
