02-11-2015, 07:28 PM | #1 |
Drives: 2017 Camaro 1SS, 2023 Sierra Join Date: Feb 2014
2014 Front turn signal burning out
Anyone else having any issues with front turn signals burning out excessively?
In the span of 1 year, my passenger side front turn signal has burnt out twice. Drivers side not at all. Just wondering if anyone else has the same problem, thanks. |
02-12-2015, 04:53 PM | #2 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
I like to put some dielectric grease on the metal part of the bulb. The oils from your finger tips will cause them to burn out quickly.
good luck Dimitri |
02-12-2015, 09:13 PM | #3 |
The Mechanic
Drives: a sports car Join Date: Dec 2011
What brand of lamps are you using? Try using a different brand such as Sylvania/Osram or Phillips.
If changing lamp brands does not work you can perform voltage and resistance checks if you're proficient in that arena. In one observed case, I created a suppressor diode circuit (alternatively known as a flyback diode) that plugged inline to the light which helped in isolating the root cause. I am not suggesting that you need to create one as well, just trying to add a little context to what might be going on. Hope this helps. JV |
02-17-2015, 05:25 PM | #4 |
Drives: 2014 v6 Join Date: Nov 2013
I just burned out my 4th bulb In a year and a half. Good thing it has warranty
