Old 02-18-2015, 12:41 PM   #1
JoeyJ
Drives: 2011 2SS/RS
2010 SS will not start
My friend has a 2010 SS Camaro that is a 6 speed , He started the car and when he moved the shifter toward reverse the car died and now will not start at all , Any clues ...
JoeyJ is offline   Reply With Quote
Old 02-18-2015, 12:45 PM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
How long was it sitting?
These cars have issues if they are not started frequently. Basically the computer is always on, and the OnStar can drain as well.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 02-18-2015, 12:52 PM   #3
JoeyJ
Drives: 2011 2SS/RS
It was just sitting overnight , It started up fine then died and now it comes up service stabili track and will not turn over .
Old 02-18-2015, 01:14 PM   #4
Spartan01
Spartan01's Avatar
Check under the hood.
Make sure that no hoses, cables, plugs are disconnected. this has happened to me a few times.
So is it not cranking at all?
If the battery is fine, then that sounds like a starter issue (let's hope)
Old 02-18-2015, 01:58 PM   #5
JoeyJ
Drives: 2011 2SS/RS
Checked all fuses and connections , Car powers up but will not even click .
Old 02-18-2015, 02:13 PM   #6
Spartan01
Spartan01's Avatar
This is most likely a starter then.
Try jump starting it just in case.
You can try contacting OnStar to see what code you are throwing, then google the code or check this board.
good luck, keep us posted.
