Old 04-13-2019, 12:20 AM   #1
Jeeno
Drives: 2010 Camaro SS
Headlight/Fog Light advice.
I have a stock 2010 SS. I like the Halo lights but they are just not as bright as newer halo's you see on other cars and rightfully so, they are 9 years old. That being said, does anyone have a way to either brighten them or a kit to replace them with that gives the car a little character?
I have seen the colored ones but I know nothing about how those work and if those are just for show and dont actually light the way at night? Would ordering just a new headlight (actual plastic part) make it look a lot brighter?
Also how difficult is it to replace the fog lights (yellow) with some brighter HIDs? I just orderd the DRL cable that will allow those to stay on when my headlights are on. Any advice would be much appreciated!
Jeeno is offline   Reply With Quote
Old 04-13-2019, 06:11 AM   #2
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
fog light bulbs (which are actually daytime running lights) are very easy to replace with LEDs
fhrex is offline   Reply With Quote
Old 04-13-2019, 07:04 AM   #3
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
What he said ^^^^ Plenty of LED options and EZ PZ install. Halos are a different story.
There's no way to brighten them or just replace them without having to replace the entire headlamp $$$ There are halo kits but they're for adding halos to non-halo cars. They require a lot of work to install and aren't as good as eom halos.
camguynj is offline   Reply With Quote
Old 04-15-2019, 07:34 AM   #4
bigwormgraphix
Drives: 1991 Z28, 2015 SS & 2017 SS
We sell Diode Dynamics led bulbs for the DRL lights on a 2010 Camaro. Easy install, just a bulb swap since you already have the adapter. We also sell the adapters.
https://www.bigwormgraphix.com/2010-...-lighting.html
bigwormgraphix is offline   Reply With Quote
Old 04-15-2019, 12:35 PM   #5
Jeeno
Awesome, thanks for the info guys. I think im going to just order a pair of those bulbs right now and be done with the fog lights.
Edit: Do I not need the adapter just the bulbs?
Old 04-15-2019, 12:40 PM   #6
bigwormgraphix
If your adapter is correct, you will just need the bulbs.
Old 04-15-2019, 12:42 PM   #7
bigwormgraphix
We also have these lights, which really improve visibility and have a white color.
https://www.bigwormgraphix.com/2010-...og-lights.html
