03-31-2015, 05:49 PM | #1 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
ATI or Fluidampr? Help me decide.
Simple question: Which one is better?
They both cost $400 region, so why one over the other? |
03-31-2015, 07:44 PM | #2 |
I just went through this same decision. After reading several reviews and articles on the fluid technology used in the Fluidampr, that was my choice. I ended up going with the 760121 (25% UD). Just ordered it today. This was the best price I have found on the internet ( http://www.dieselstuff.com/flu760121.html ), and that was with free shipping. But I am not familiar with that vendor, so I just contacted a few other vendors that I was comfortable with until one of them agreed to price match. I think Summit will even price match if you call them.
04-01-2015, 04:38 PM | #3 |
Thanks blazzin1 !
You made the decision a no brainer. Jegs makes it super easy to enter the online price match info. Just finished ordering the Fluidamper. |
04-01-2015, 07:45 PM | #4 |
Glad I could help with your decision! You'll need a Gates K060827 (or equivalent) belt. I'm told the K060819 that is recommended in the Fluidampr installation instructions won't fit….too small.
04-01-2015, 09:02 PM | #5 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
04-01-2015, 10:31 PM | #6 |
Drives: 2014 2SS 1LE Join Date: Sep 2013
I also went with fluidampr I epected not to underdrive it. I really like it and reccomend it.
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
04-02-2015, 02:39 AM | #7 |
Gates also makes a Racing version of the K060827. its K060827RB its blue and made for hi rpm applications. http://www.amazon.com/Gates-K060827R.../dp/B000JZFN6M read the box. It says not to remove it from the box until your going to use it.
04-02-2015, 09:21 AM | #8 |
Drives: 2015 Camaro SS 1LE Join Date: Dec 2014
Did a cam swap last month. Originally purchased a fluidampr but returned in favor of the ATI. Didn't like the fluidampr weighed 15 lbs. Nearly 7 lbs more than the ATI. From other LS forums the majority preferred ATI.
04-02-2015, 09:26 AM | #9 |
Drives: 14 Camaro 1LE,328i, and some Hondas Join Date: May 2014
I'd take the ATI over the fluidampr, but that's just me. They're both nice pieces, and I don't think you can go wrong with either one. I recently bought a 10% underdrive ATI for my build.
14' Camaro 1LE - Now self-tuned
FRH ported heads, Cam Motion LL solid roller, Jesel rockers, Morel lifters, Kooks headers, Corsa exhaust, ADM intake, Stock compression/bore/stroke 551whp 504wtq |
04-02-2015, 02:37 PM | #10 |
Drives: camaro ss\rs Join Date: Jun 2014
i'm really interested in a dampr. are the ATI lighter than the stock pulley?slp made a dampr lighter than the stock
04-02-2015, 03:13 PM | #11 |
04-02-2015, 05:33 PM | #12 |
old school chevy rodder
went with the fluidampr it underdrives what should be and not what shouldn't along with it viscous silicon fluid tech. I am a old hot rodder. And some brands may come close to their quality but not close enough, some brands suck and can actually fall apart and are not much better than stock for eliminating the more varied vibrations from a cammed motor. The fluid amprs directions I got from summit recommend a belt length with a wrong gates number BTW for the underdriven belt.
04-02-2015, 10:29 PM | #13 | |
04-03-2015, 06:42 PM | #14 |
So, I went with the stock diameter balancer. Will I still need the Gates belt? The OEM one will work fine, right?
