01-26-2012, 11:26 PM | #1 |
Maroboy2001 AKA Offset
Drives: Boosted Trans Am Join Date: Oct 2011
My blacked out headlights/tail lights and berger panel
Working on restoring the headlights before and after flat black paint.. here is where I messed up..Let's see if you can figure out what I did wrong. my berger panel. Flat black with 1 coat of clear to go with the tail lights better pics coming tomorrow. next I'm getting my white stripes taken off and replacing with black that stops at the spoiler before now... my mistake was that I painted the reflector part of the headlights, that's what gives it that shine for a distance so now I have HIDs that I cant even see at night with...(serious brain fart) so now I'm in the process of looking for either reflector paint or film to replace what I painted ...
01-26-2012, 11:56 PM | #2 |
Don't Like it? Suggit.
Whoops, painted the whole thing, LOL
Almost a whistler mod... I don't suppose that's plasti-dip?
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
01-27-2012, 07:09 AM | #3 |
Revo LOVES plasti-dip!
01-27-2012, 08:47 AM | #4 |
Nope just spray flat black :( any idea what I could use to make the light reflect in the headlight?
01-27-2012, 10:00 AM | #5 | |
Gunning for Sixth
Drives: '03 ZR2 Blazer Join Date: Sep 2008
Keep the plastic lenses off the old ones as spares. Ever crack the lens on a new one, just pop the housing back in the oven and RTV the 'old' lens from your snafu onto the new housing. |
01-27-2012, 04:27 PM | #6 |
Drives: 1996 Camaro RS convertible Join Date: May 2009
Why do you lows and highs not turn on together? Never seen a 4th gen camaro that didn't.
01-27-2012, 09:59 PM | #7 |
I thought it was a law that there had to be a transistion between high beams and low beams thats why retro fit is illegal
01-27-2012, 10:37 PM | #8 |
Quit being a pu$$y
If it's just flat black paint try using thinner or something to remove the paint. If that doesn't work...
Use A/C ducting tape. Not the regular grey "duct tape" that everyone knows. There is some VERY reflective ducting tape that is basically aluminum foil tape.
01-28-2012, 05:28 AM | #9 |
Where can I get that at?
01-28-2012, 11:37 AM | #10 |
Quit being a pu$$y
01-28-2012, 10:56 PM | #11 |
Gunning for Sixth
And if you have any left over.. it's fun to play with.
We used it to cover up exhaust manifold ports on cylinder heads when the manifolds are off. It'll stick to anything and stay put as long as it has contact area. It does wrinkle easy though, so it could foul up the reflective properties of the lens. All else fails, just order a used pair from a junk yard or something. |
02-18-2012, 02:12 PM | #12 |
Drives: Heel toe express.. Join Date: Dec 2009
Reflective duct tape would work but I wouldnt go that route unless you want your headlights to look terribly ghetto rigged lol. Best bet is to just bite the bullet and pick up a new set of hedlamp housings. They can be found on Ebay pretty cheap.
Camaro SOLD :(
Thread Tools | |
