05-24-2014, 03:38 PM | #1 |
Drives: 2013 ZL1 416 Join Date: Feb 2013
Does the Ctsv 6 and 4 piston caliper fit the gen5 camaro
looking for a zl1 brake upgrade and seen the ctsv 6 piston and 4 piston brembro's look the same was wondering if anyone had info
they are way cheaper new |
05-24-2014, 03:55 PM | #2 |
Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
yeah pretty sure they do, there are several places that offer swap kits for the Camaro
there is a thread or two on it, but all the pictures are gone: http://www.camaro5.com/forums/showthread.php?t=71401
I'm only responsible for what I say, not for what you fail to understand.
05-24-2014, 03:57 PM | #3 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
The front 6 pistons (The fronts of the CTS-V and ZL1 are identical other than color and labels) do but the rear 4 piston do not. The reason the rears don't fit is because the CTS-V uses forward mounted rear calipers, If you do the upgrade just use the rear SS brembos. Also when ordering stainless steel lines you can have to order the ZL1 setup in order for it to work.
05-24-2014, 03:58 PM | #4 |
ya thanks just seen it and another post below lol im not the first to have realized this
my bad sorry to all that wana say hey use the search dummy lol |
05-24-2014, 04:02 PM | #5 | |
I have the 2011 2ss/rs with the stock brembo's |
05-24-2014, 05:23 PM | #6 | |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
You dont need them because the rear brembos on the CTS-V and Zl1 are the same as the SS's... you just need the front calipers.
05-24-2014, 05:30 PM | #7 | |
But just like lil nasty said there is no need for either the CTS-V or ZL1 rear calipers, they are the same as your stock Brembos. Sent from my HTC One_M8 |
05-24-2014, 05:35 PM | #8 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Parts Needed...
CTSV Calipers Pins and Clips Pads Rotors ZL1 front shields- protects front ball joints from rotor heat new caliper mounting bolts Goodridge or equivalent lines which include crush washers DOT 4 fluid
05-24-2014, 06:44 PM | #9 |
so zl1 and SS rears are the same caliper ?
do they both have the same size pistons ? do Ctsv rears also have same size pistons ? |
05-24-2014, 06:50 PM | #10 |
COTW 5/06/2013
Rears are the same, just the location changes on the mounting. so the bleeders and crossover tubes are the only differences.
05-24-2014, 07:01 PM | #11 |
any one have pics of the 3 calipers to show what is diff
05-24-2014, 07:04 PM | #12 |
COTW 5/06/2013
ZL1 and SS is paint only.... Will see if I can find the rear V pics
05-24-2014, 07:09 PM | #13 |
do u have pn for the zl1 and ss calipers wan see which way is cheaper by the time its powder coated
05-24-2014, 07:09 PM | #14 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
I install front and rear CTSV calipers. Of course I had them all disassembled to be painted IOM. I sold the full SS system to a G8 car. When they rebuilt the calipers they built it so the leaders were in top and cross over tube was on the bottom.
Sent from my iPhone using Tapatalk -
Thread Tools | |
