06-27-2012, 09:01 AM | #1 |
P-zero thoughts
So we all know that pirelli p zeros are great tires... but who has problems keeping the rubber on them? i do not burn out (often) maybe once in a blue moon and i still cant keep the pzeros on... i only have 22750 miles on my car... ive had to replace the rears once already and by the end of the summer probably going ot have to replace them again... ended up getting the new cooper tires on the front and i plan on putting them in the back becuase they seem to have a better lasting time then the p zero's... just want to know if you guys think its worth the p zeros or not
2010 Camaro 2SS/LS3
Magna Flow Street series Exhaust Airaid Intake+throttle body Custom tune by Bob Morreale www.thetuningschool.com QTP Electronic Exhaust cut-outs 12'' Alpine type R with 1500watts double ported box Tinted windows 392RWHP on Mustang Dyno #13933 |
06-27-2012, 09:16 AM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
NOPE.....to soft for my taste......they are good tires, but I nwanted a Ultra-High Performance tire that would last a bit longer......which is why why I put a set of Generals AS-03's. I love them.
06-27-2012, 09:36 AM | #3 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
P-Zero's are overall very good tires. You can drop the air pressure at the track if you need a little more hook but they are still a little traction limited. Handling is great but the ruts in the road pull me all over the place. Mine will need to be replaced soon as the fronts are down to the wear bars and the rears are getting close at 22k miles. I will consider Vredestein and the P-Zeros when shopping. I doubt the Vredesteins will give me any more traction at the track but they might be better all around. JMO.
-Mark. |
06-27-2012, 09:42 AM | #4 |
I just put coopers on the front... actually really great tires for a great price may want to check them out when ur shopping
2010 Camaro 2SS/LS3
06-27-2012, 09:56 AM | #5 |
Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
My 2LT has the all weather P-Zero Nero. I have 36k on them, and thinking I can get another 3-5k. I know...totall different then the summer P-Zero, but it seemed like a general question. On my 4th Gen Z-28 (when I owned it in the early (90's) I would get about 25k out of my summer Z rated tires. Goodyear and BFGoodwrench tires.
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
06-27-2012, 10:25 AM | #6 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
Look into the Hankook Ventus V12 K110. It will cost you like $750 for a set of 4 tires. Can't beat that and placed 2nd in Car and Drivers tire test out of 10 different tires.
06-27-2012, 11:08 AM | #7 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
One problem with softer tires is they don't last as long as some other tires.
A good example is the NT05 Nittos which only have a 200 tread wear (I believe). They have excellent dry traction, but that 200 tread wear lets you know they're not going to last all that long. So if you're looking for a long lasting tire, focus on a higher tread wear rating. The higher the number, the longer the tire will generally last. But on average, the higher the tread wear the less dry grip they will have. |
06-27-2012, 02:56 PM | #8 |
Drives: 2012 AGM SS Join Date: Jun 2012
P-Zero's are great for a summer tire. The wear is too much for my tastes on my last car they lasted 30K Miles on all 4 tires. On a Camaro I looked at with 30K miles they had worn through two pairs already on the rear. I probably won't be replacing mine with the same tire but hopefully I get 30-40K miles out of them at least.
06-27-2012, 03:07 PM | #9 |
Drives: 2012 2LT/RS 6L50 automatic TF-3 Join Date: Apr 2012
can anyone tell me what the max speed rating on the p-zero's are?
Its better to burn out , than to fade away.
06-28-2012, 04:34 AM | #10 |
Drives: 2019 Camaro 2SS 1LE Join Date: Aug 2011
186 mph, "Y" rating.
06-30-2012, 09:41 AM | #11 |
Thanks for the info.
06-30-2012, 05:26 PM | #12 |
Drives: 2010 Camaro 2LT Victory Red Join Date: Feb 2011
Just got Cooper Zeons Rs-s from discount tire for like $775 shipped.
Had them mounted and balanced today on some new chrome rims |
06-30-2012, 06:15 PM | #13 |
Love everything about the P-zeros except the tire wear...
On my second set of rears and they need replacing in another 5k (30k on the Odo). No (full) burnouts, hit the track a couple times a year and plenty miles of spirited driving. I plan on getting a set of Mickey Thompson Street Comp Tires very soon... UTQG 300 AA A vs 220 AA A
