Old 05-16-2014, 06:42 PM   #1
12 ZL1 #1725
12 ZL1 #1725's Avatar
Drives: 2012 ZL1 Black 6M
Claying Question??
I clayed the car today and notice a lot of high / low spots on the car.... I didn't use pressure when I clayed.... Just kept going over until it was smooth.... But after I wiped the detail spray off..... there were shiny and dull spots?? Is this normal???? Any input is greatly appreciated
Sit Back and Enjoy The Ride!!
12 ZL1 #1725 is offline   Reply With Quote
Old 05-16-2014, 06:45 PM   #2
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
It's not likely that you marred the paint if you used a fine grade clay with light pressure. Pics would be helpful.
Laus Deo
charlietuna is offline   Reply With Quote
Old 05-16-2014, 09:33 PM   #3
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Orange peel possibly.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 05-16-2014, 10:56 PM   #4
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
My thoughts too?
13lstuner is offline   Reply With Quote
Old 05-16-2014, 11:03 PM   #5
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
My guess if it's dull it's because you have some clay residue left on the paint, not having the area lubed well will that.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 05-17-2014, 09:51 AM   #6
forklord
forklord's Avatar
Drives: 2010 2SS
i dont like clay. if any bit of dirt or anything gets in itll scratch your paint.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 05-17-2014, 10:09 AM   #7
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Lol
Sent from my HTC One using Tapatalk
[B]
Old 05-17-2014, 11:04 AM   #8
forklord
forklord's Avatar
Drives: 2010 2SS
Originally Posted by CamaroDreams07 View Post
Lol
i know. im probably not doing it right but i just dont trust it.
Old 05-17-2014, 11:24 AM   #9
JTruck
JTruck's Avatar
The entire purpose of claying is to remove the dirt from the paint and put it in the clay.
Old 05-17-2014, 03:20 PM   #10
12 ZL1 #1725
Here's some pictures.... But they didn't turn out too good? This is the trunk... Middle is the dull spot...
Old 05-17-2014, 03:21 PM   #11
12 ZL1 #1725
Front... Hood
Old 05-17-2014, 03:23 PM   #12
12 ZL1 #1725
Still front
Old 05-17-2014, 03:24 PM   #13
12 ZL1 #1725
If you look at the pictures... It looks like water spots.. But it isn't.. It's where it is dull...
Old 05-17-2014, 03:42 PM   #14
13lstuner
13lstuner's Avatar
I'm on my phone so I can't see it that well, but that looks like residue of some sort. What have you tried to remedy it?
