04-27-2012, 09:59 PM | #1 |
Drives: 2012 1SS Join Date: May 2011
stupid question
I have a 2012 ss and I was wondering if it's ok to push the car in neutral without turning the car on. I remember awhile back someone said they did this and it messed with the wheel sensors....oh and it's stick
04-27-2012, 10:08 PM | #2 |
knows 2 facts about ducks
Yes you can push the car while it's in neutral
04-27-2012, 10:12 PM | #3 |
thank you
04-27-2012, 10:39 PM | #4 |
H1 OFCR
Drives: 2013 ZL1 Blue Ray Metallic Join Date: Jun 2011
LOL
Corsa
Rotofab BBK ZL1 Hood/Fascia AAC Afterburners/Sidemarkers Havoc Black Chrome 5% Tint/20% Smoked Taillights |
04-27-2012, 10:45 PM | #5 |
Drives: 2010 2SS/RS RJT Join Date: Jun 2010
9.75 @ 139mph, 1.41 60ft, 2010SS, JRE Built!
04-27-2012, 11:41 PM | #6 |
LS3 Black Widow
Drives: 2012 45th 2SS LS3 and 1968 Mustang Join Date: Nov 2011
Nothing wrong with that question IMO.
04-28-2012, 05:55 AM | #7 |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
The only dumb question is the question that doesn't get asked.
Manual okay, can't with an automatic. No lube circulation in an automatic. You'll be fine. Sent from my DROIDX using Tapatalk 2
Bye bye, Bumblebee!
04-28-2012, 06:14 AM | #8 |
Their are no stupid questions. Just stupid people.
2011: 2SS/RS Camaro Synergy Metallic
04-28-2012, 06:22 AM | #9 | |
Drives: 2011 Coupe, 1LT, A6, No RS Package. Join Date: May 2011
I have an automatic and sometimes when I am shining my tires I do as much as I can while the car is parked, and because I don't want to start the engine just to move it a bit, I then put it in Neutral to push it forward a little bit so I can get the bottoms of the tires...then I push it back. Am I actually hurting something by doing it that way?
Never Underestimate The Power of Forums
04-28-2012, 06:28 AM | #10 |
Drives: 2011 Camaro SS Join Date: Aug 2011
No I highly doubt you are hurting it in any way, your not building any friction up just moving it a couple of feet.
04-28-2012, 06:35 AM | #11 | |
I'll be back...
Since a manual transmission uses the rotating assembly to circulate lube to the bearings instead of a pump that is driven by engine rotation (like an automatic does), you get plenty of lube to the bearings even when the engine is off, while pushing or towing the vehicle. Sorry, I should have elaborated.
Bye bye, Bumblebee!
04-28-2012, 06:40 AM | #12 | |
To my brother Scott, Thank you for your gift. I would give it all back just to have you here again.
Scott N. 08/05/64 09/28/2010 |
04-28-2012, 06:57 AM | #13 | ||
Chiefish strych9 nitrorcr1787 Thank you. (PS: Never a problem elaborating, it's always better to understand the full reason things happen)
04-28-2012, 07:22 AM | #14 |
Totally into it
Drives: '67 427vette/'11 Pacecar/'02 BMW ci Join Date: Feb 2011
So, just to clarify, if you are coasting in an L99, and the engine stalls, you either have to stop immediately or your bearings are toast?
____________________________________THERE MUST BE A SUPPORT GROUP FOR THIS ADDICTION. AM I IN THE RIGHT PLACE?
