09-01-2014, 11:27 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2014
Resonator vs Muffler Delete
Hey all, been reading all the different threads about making the Camaro louder.
I've got a Automatic L99 2010 2SS and I also want a louder exhaust and more throaty rumble...but I also don't want to pay a lot of money. So, questions! 1. What the heck is a resonator? (N00b question, I know.) 2. Does deleting the resonator change the sound of the exhaust more or less than deleting the mufflers? 3. Should I get a x-over pipe and if so, why? What does it add? Thanks! Rob Last edited by dreadpyrat; 09-01-2014 at 11:30 PM. Reason: added engine details |
09-01-2014, 11:37 PM | #2 |
Drives: 15' Scat Pack Join Date: May 2014
Deleting the mufflers will make it much louder than just deleting the resonator. I did a muffler delete and was happy with it but wanted a little more, so I bit the bullet and did the resonator too and I am very happy that I did. Honestly not really sure how much of a difference doing an X pipe makes but the shop that did the work on my car put one on and all I can say is that if you are on the fence about doing a muffler and or resonator delete, DO IT. I think I spent about 250 total, new tips and x pipe included.
09-02-2014, 11:07 AM | #3 |
Drives: Supercharged 2013 2SS/RS Join Date: Sep 2013
Mine has a resonator and muffler delete with magnaflow x pipe to replace the resonator. This being said. 40 for mufflers off, 40 for resonator off and x pipe in, 70 or so for x pipe. In total it was definately worth it. But I hate the sound of the 4 cylinder shut off, so I drive mine in "paddle shift" mode all the time. As you're driving, down shift and to cuts the AFM completely out until you put it in park, reverse, etc then you have to do it again.
09-02-2014, 01:43 PM | #4 |
Thanks guys, appreciate the info. I'm really struggling to figure out the right way to go without spending a fortune.
It seems the cutting out the rez and/or mufflers is not only cheap but gives instant volume to the exhaust note. So why do so many go for a Cat-back or Axle-Back system? And, if you do go with a CB or AB system, do you still want to cut out the rez or mufflers? |
09-02-2014, 09:15 PM | #5 |
Drives: 2010 Camaro 2SS/RS Join Date: Aug 2012
Get rid of the mufflers and resonators. They are ugly and heavy and sound much better without.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers 3" Full exhaust w/ Off-Road H-Pipe Bo White Ported Throttle Body Hurst Short Throw Shifter Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires Build Thread |
09-02-2014, 09:23 PM | #6 |
Drives: 2011 1SS LS3 Join Date: Nov 2011
If you go with CB or AB... You'll have aftermarket mufflers... I ran with a muffler delete for a while and got a lot of complements... Then went to long tubes with no cats and no mufflers... Def turned heads but had super bad drone. This past Saturday I had two j-pipes welded on and the car sounds amazing!
TSP LTs w/ catted extensions, Muffler delete, Haltech yellow jacket, Hurst short throw, oracle halos, oracle interior ABL kit, big worm graphics complete black out kit, full aftermarket stereo system
09-02-2014, 09:25 PM | #7 |
Drives: 2010 Camaro SS Join Date: Apr 2013
Deleting the secondary cats on my LS3 made more of a difference than deleting the mufflers.
TSP 1 7/8 LT, ADM Race Cold Air w/ Race Scoop, GPI SS3 LS3 Cam, Powerbond UD, 3.91 Gears, GPI Posi Mod.
498RWHP/451RWTQ |
09-02-2014, 10:56 PM | #8 |
Cool, this helps! Ok, how does this sound as a plan then: delete mufflers(but not resonators) and have J pipes welded in for drone relief.
09-02-2014, 10:59 PM | #9 |
If you are L99 i think you will need to delete resonators also.
498RWHP/451RWTQ |
09-02-2014, 11:24 PM | #10 |
Thanks Muddflap, can you tell me why? I'm still not clear on what purpose the resonators actually serve.
09-02-2014, 11:25 PM | #11 | ||
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
09-03-2014, 10:04 PM | #12 |
Did you go on YouTube and listen to different set ups? That's what i did and ended up spending $70 to get the mufflers taken off and kept the factory tips...
