12-21-2012, 07:58 PM | #1 |
Drives: 2012 Camaro 2SS LS3 Ashen Grey Join Date: Mar 2012
Pfadt ZL Spec Sway Bars Question
Hey guys with the new ZL Spec adjustable front and rear sway bars what do you think would be the best setup for a street car? Once the Stage 4 is installed I plan on lowering 1" to no more than 1.5" making the front and rear completely level and tightening up the dampers for a bit more stiffer ride than stock but not to stiff. I am also going to ask the guys installing it at Raymond's to give me a non-aggressive street alignment (whatever will give me best wear on the tires). So my question is with that setup what will give me the most balanced settings for understeer/oversteer? Should I just have the front and rear bars set the same to the middle settings? Thanks for your help and inputs.
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
12-21-2012, 08:28 PM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
I have mine on set at the middle hole.Very neutral with a bit of understeer. Jordan at JDP runs them and I followed his recommendation. Works very good doing Auto x.hat, the springs and a performance street align and It handles just great without oversterr problems
12-21-2012, 08:34 PM | #3 |
Do you know if most people prefer a tad bit of understeer or oversteer. Like if you had to have one or the other which would be preferred?
12-21-2012, 08:51 PM | #4 |
Under. for saftey, and at the track to. Dont know about you, I'm not that good to be know how to drive the car perfectly in any condition. A bit of understeer you can correct the car easier and get it where you want. Oversteer, and I had that once on my 4th gen,You lose it at the wrong time and you better have enough room to recover with nothing in your way!
12-21-2012, 08:54 PM | #5 |
Drives: 2010 2SS/RS Join Date: Mar 2010
I am also set up on the middle setting for both front and rear ZL1 bars.
I wont be adjusting them until I get some sort of wheel/tire setup. Like VR Baron said, just a tad of understeer currently. This is the optimal setup for the street in terms of safety. Ive had my stage 4 installed for 2 months now and that small bit of understeer comes handy on the streets. You'll love it!
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers "Information is the oxygen of the modern age" Build Thread |
12-21-2012, 09:13 PM | #6 |
And the bars do wonders around the cones, flat, prdictable and you can focus on driving and the course, not muscling the car around with all the understeer.
12-21-2012, 09:34 PM | #7 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
I have front middle rear stiff and it handles great
Ported intake manifold and throttle body kooks 2" headers no cats
12-21-2012, 09:37 PM | #8 |
12-24-2012, 12:31 AM | #9 |
Running stock plan on going to 295/35/20 all around. Have a little bit of oversteer but I lied it better than the middle setting
12-24-2012, 10:50 AM | #10 |
When you go to the square tire setup then stiffer rear should be better and desired I would think. Thinking on doing stock 20x9's all around as I have a extra set and 285's .
12-24-2012, 07:46 PM | #11 |
Thats my plan Pete from Pedders really recommends that setup
