11-19-2013, 01:33 PM | #1 |
Master of Nothings
what do you get?
I was thinking the other day that my 2010 2LT is supposed to get around 29mpg highway. I don't seem to get that. I get more around 22-23mpg. Does anyone on here get close to what they are "supposed" to get in mpg? Is there something else I can do to improve this?
2010 Chevrolet Camaro 2LT/RS |
11-19-2013, 01:37 PM | #2 |
The gritos pollo!!!
my 1ls has no issue hitting 30 on road trips
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
11-19-2013, 01:39 PM | #3 |
Drives: Camaro Join Date: Dec 2012
The only way to get the MPGs you're "supposed" to get on these cars is to drive 55 in 6th gear constantly - never stop. At least with the V8 M6.
11-19-2013, 01:42 PM | #4 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Well, the mpg is usually skewed.
The guys who do them will typically run on a closed super-elevated track, and will put huge rims with small tires and pump up the PSI to way beyond spec for max MPG. I have an SS with just about every possible mod and when cruising on the highway I get around 20-21 mpg
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
11-19-2013, 01:54 PM | #5 |
Right, but I believe your LS is geared differently than the LT, specifically to get higher MPGs. It also probably has smaller tires (less drag/resistance) and all-around less weight manual tranny vs automatic, for instance).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
11-19-2013, 01:55 PM | #6 | |
11-19-2013, 01:57 PM | #7 |
Austin LT
Drives: 1LT - Airaid,JBA Axleback,VMax PTB Join Date: Jun 2009
Only time I see 26+ is when I reset the counter and drive exclusively on the highway. Any stop and go or city driving skews the numbers to 23-24.
11-19-2013, 02:18 PM | #8 |
Drives: 2014 2SS 1LE Join Date: Oct 2013
Something must be wrong with my 1le I'm getting 14-15 city driving and the only freeway trip I got 20. It probably has to do with the nut behind the wheel though.
11-19-2013, 02:28 PM | #9 |
Drives: 2010 Camaro 2LT RS Join Date: Sep 2012
Who cares I don't buy cars for gas mileage.
If you're not living on the edge, you're taking up too much space.
11-19-2013, 02:31 PM | #10 |
The gritos pollo!!!
what do you get?
I know the 2ls auto is set of for highway gears, the manual has the same gearing as a lt I know the steelies are lighter than the 20s but I'm getting that pulling 2300 rpms running 75
______
11-19-2013, 02:32 PM | #11 |
Timna, that sounds about right. I only get 20-21 if I am cruising on the highway at around 65, 6th gear, cruise control on. Otherwise I am getting around 14-17 highway.
11-19-2013, 03:03 PM | #12 |
Drives: 2014 2SS/RS Convertible Join Date: Jun 2013
The only way you are going to get close to 29 mpg in a 2LT is to set the cruise at 55 or 60 in 6th gear on a level stretch of road and never use the brakes. In real world highway driving you would be lucky to see 25. Around here highway speed is 75 - 85 and low 20s is the best mpg I get at that speed.
11-19-2013, 03:11 PM | #13 |
Drives: 2011 IBM 1LT w white Rally Stripes Join Date: Aug 2012
To adequately answer this question you have to take variables into account:
* transmission type * fuel grade * driving long stretches versus city traffic w frequent stop and sit In my case, city driving in my LT is pretty brutal on gas mileage. Mine's an automatic so my average is showing 17.5 MPG. Again, because I sit in traffic it's going to be a lot lower, and I also use the minimum Octane rating. Gas with higher octane ratings mean the engine has to work less and probably would increase mileage by 1-2, but the cost offset is too much for me. Also, manual transmissions will get better MPG that autos but not much.
11-19-2013, 03:17 PM | #14 |
Drives: 2010 rs 2lt Join Date: Aug 2012
I have gotten 27-28 strictly highway , averaging close to 70mph , I am sure if I drove 50-55 I could get close to 30,
