11-30-2019, 12:07 PM | #1 |
Roto fab fitment
Has anyone ever had issues getting a Roto Fabb to line up in their ZL1? I'm installing my Roto Fab right now and there is absolutely no way this elbow will be able to mate with the throttle body fitting. I have tried bending and forcing and it's just not happening. I followed the instructions closely step by step and I lined everything up like they say. I feel like either I have something on wrong or this thing isn't made properly.
"Pretend you are smart, quote somebody famous." - Me |
11-30-2019, 12:28 PM | #2 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Here is a picture of mine...
11-30-2019, 12:30 PM | #3 |
Team 913
Might want to push the two plastic pieces together more into the coupler
11-30-2019, 12:37 PM | #4 |
Drives: 2017 ZL1 Join Date: Jun 2017
Did you buy new? That heat shield does not look right for a zl1. Looks like an SS heat shield
11-30-2019, 12:41 PM | #5 |
You are 100% correct. I just got off the phone with them. They sent the wrong heat shield. Theyre sending the correct one but it won't get to me until Tuesday at the earliest.
11-30-2019, 12:44 PM | #6 |
Oh I pushed! Lol. Turns out...I have the wrong heat shield. They sent me the SS shield and not the ZL1. Is this all because I haven't updated my avatar or signature pic?!?! Lol
11-30-2019, 12:46 PM | #7 |
Drives: 2013 ZL1 Join Date: Dec 2015
I have this on my 2013 ZL1 and yesterday I wanted to remove the filter and put a new one on, but there does not seem to be any clearance and I didn’t want to force anything. I didn’t put it on myself. Had a shop do it. Help
11-30-2019, 01:39 PM | #8 |
You have to remove the shield to remove the filter. It even states to hold onto the instructions for that reason. It's not super hard. I'm sure you can download the instructions from somewhere. If you want I can PM the pages to you. All you'll need is a 10mm, 8mm, 7mm, and a phillips screwdriver (I think that's all).
11-30-2019, 01:41 PM | #9 | |
11-30-2019, 03:00 PM | #10 |
Drives: 2013 BRM ZL1 Camaro M6 Join Date: Feb 2014
I find it easier to remove the wheel and wheelhouse liner, to then remove the air filter through the bottom. I have the washer bottle relocation with Big Gulp, but even if you don't, I think you will find this is a lot easier than wrestling with disassembly and then reassembly of the heat shield and air tube. Another option which I decided against, is to relocate the earth cable and jumper lead post.
11-30-2019, 03:42 PM | #11 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
The only hard part I found was making sure the bottom was fully seated on the frame and pushed all the way down and not still on top of that wire or hose whatever it was running there too.
12-01-2019, 06:28 PM | #12 |
Drives: 2013 Camaro ZL1 Conv. Join Date: Apr 2016
12-01-2019, 06:33 PM | #13 | |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
12-01-2019, 07:00 PM | #14 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
