Old 11-09-2017, 10:08 AM   #1
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
Tire wear question and next set suggestions
Size:  338.7 KBHey guys just wondering if this is normal type of wear for aggressive Street setup? When we did the alignment awesome guys system crashed before the print out the sheet for me but we went with about a -2.1 camber on the front 0toe and I can't remember how much negative on the rear not really concerned about the rear tires most of that from stormy burn outs near the end but the front innerwear has steps and I was wondering if that's maybe a result of negative toe not an expert on this stuff just want to throw some new tires on there and it handled great did 4 autocross events and about 10,000 km of Highway type driving also like to drag race locally a few times a year probably try a different set any suggestions welcome!
JPSS Blackmagic 32mm rear swaybar caster locks and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body Cold Air Inductions c.a.i.MightyMouse Catch can Solo High Flow cats JBA silver shorty headers, npp short throw shift and lifetime xm3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings Verona XO wheels/ccs sp16a track set, mild to wild, acs ground effects
Bretts is offline   Reply With Quote
Old 11-10-2017, 08:16 AM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
Yep, I had a set wear the inner tire off and the alignment was a little off. I would say it looks the same for you, not a lot but noticeable. the tires look like they provided many fun miles, throw a new set on and keep going (after the alignment).
BMR Suspension, SLPTVS2300, GFORCE Driveshaft & HalfShafts, Kooks with cutouts and other fun things.
Old 11-10-2017, 09:13 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
search the forums...somebody has track alignment spec's...JDP maybe?
2010 SS 2SS M6-Spectre CAI-JET TBS-JBA Shorty Headers-ARH H/F Cats-Doug Thorley axle back-MSD 12v coil harness mod-PAC 1218's-BTR 3/8 7.4 push rods-Powell Machine bronze rocker bushings-Prothane motor mounts-Prothane rear sub-frame inserts-BMR Trailing Arms & bushings-1LE 3.91's-1LE axles-Ford S-spring posi-mod-Tune by RDP dynoSteve!(Woot)-Daily Driver-119K!-12.7 at 112-1.9 60'(3.45's)-BFG Comp-2 Street Tire-stock size on ZL1 reps(20x8.5)(20x9.5)-DR's Nitto NT05R(305/45) on Motegi MT120 18x9.5-12.1 at 114-1.7 60'(3.91's) All work by me...
Old 11-13-2017, 09:05 PM   #4
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
thanks guys weird didn't get an alert to the reply's was thinking the site was a ghost town lol
Old 11-13-2017, 09:10 PM   #5
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
actually Jordan@ JDP gave me this alignment my guess is something changed up front or i was running to soft
My Michelin pilot 4 set are a week out guess shes got to go on the rack for a check on the alignment
