04-03-2014, 07:48 PM | #1 |
Trailing arm help
How do you get the bolt out on the outer bushing ?
TSP 1 7/8, CNT catback, VMAX, CAI intake, ADM scoop, 3.70s, Adm Tuned(374/391), SLP UDP, 18" nurbs/NT05r's , 3200 stall, Granatelli trailing arms....1/4 mi best 12.7
04-03-2014, 07:50 PM | #2 |
It's too long and hits the lower control arm
04-03-2014, 08:07 PM | #3 |
Drives: cars Join Date: May 2011
Need to use an open ended wrench to fully disengage the threads. After some wiggling, pulling, and cursing it comes out. Snug but doable.
04-03-2014, 08:29 PM | #4 |
Trailing arm help
It's impossible.. I was able get bolt loose but won't pull out because it hits lower control arm
04-03-2014, 08:31 PM | #5 |
Used 2 DIY threads and neither mentioned this ! As usual my DIY 's become DI dont's
04-03-2014, 09:58 PM | #6 |
Drives: '69 SS Convertible Join Date: May 2009
I don't remember it being any issue. Can you use a pry bar some how?
Where in TX are you? If you're not far from me I can try to take a look? Maybe take some pictures and post them so we can see the problem.
Build Journal |
04-03-2014, 10:08 PM | #7 |
No the head of the bolt hits arm straight across and bolt still has few more inches to pull out
04-03-2014, 10:08 PM | #8 |
West Texas
04-03-2014, 10:10 PM | #9 |
A bit far from my area.
Can you post some pictures and lets see if we can get you some ideas.
Build Journal |
04-03-2014, 10:16 PM | #10 |
I'm curious how much clearance you need. I just looked at some of my pictures and I can see where it would be close but maybe a little hammer tapping from the other end will get it past? Just depends on how much it's hitting the LCA.
Also, can you take some pressure off the LCA? Maybe use a jack to lift up on the LCA some and then a little hammer action......just brain storming.
Build Journal |
04-03-2014, 10:21 PM | #11 |
04-03-2014, 10:21 PM | #12 |
This picture kinda shows it
04-03-2014, 11:34 PM | #13 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
Are you talking about the outside end, closest to the rotor? If so, it looks like the bolt may be in backwards. The nut should be on the rear facing side and the head facing the front. Maybe it got installed that way when the control arm was disassembled and separated from the spindle (?). You might have to remove the control arm to get the bolt out.
Meh
04-04-2014, 05:58 AM | #14 |
Drives: 2010 Silver SS/RS LS3 Join Date: Nov 2011
When you have the bolt pulled out as far as you can, try to spin it counter clockwise while tryin to wiggle it around the control arm. It'll come out, don't remove the control arm.
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB. Rhino79 Dyno tuned...405 HP/399 TQ |
