Old 04-18-2016, 08:24 PM   #1
10' Camaro SC
10' Camaro SC's Avatar
Drives: 2010 Camaro SS 5th Gen 6spd SC
Anyone riding on ST coilovers? Ride quality?
http://www.stsuspensions.com/product...kit-14429.html
They are suppose to be same valving/springs as V1 and made by KW. Only thing is its galvanized zinc instead of Stainless steel body.
Priced very well.
10' LS3 Camaro 2SS (blacked out) - Edelbrock Supercharger, ZL1 rims, 275/315 tires, XS Power LT headers, 3" exhaust, twin tips, Edelbrock CAI, ZL1 fuel pump/ADM FPCM, VMax ported TB, JRE fuel mod, TR6ix plugs, ZL1 spoiler/splitter/grille, KW V1 coilovers, BMR sway bars, strut tower brace, trailing arms, toe links, Prothane radius arm & subframe bushings, Slotted rotors, Hawk pads, SS brake lines, HURST short throw shifter, Scosche dash kit, Pioneer 7" radio, backup camera, Dyno - 520 rwhp/tq
10' Camaro SC is offline   Reply With Quote
Old 04-23-2016, 11:08 AM   #2
p.s.
Drives: 2014 v6 manual
Priced very well.
I would be if they actually fit the sway bar link of my 2014. All i can say right now is they look nice in the box and say kw right on them.
p.s. is offline   Reply With Quote
Old 04-23-2016, 11:46 AM   #3
10' Camaro SC
The front endlink you mean? Why doesn't it fit?
Old 04-23-2016, 11:54 AM   #4
p.s.
It's only big enough for the old smaller one to pass through. they changed the front sway bar when they switched to the electric rack.
Old 04-23-2016, 12:08 PM   #5
10' Camaro SC
I have a 2010 with the FE4 conversion and BMR sway bars. Would these fit?
Old 04-23-2016, 12:10 PM   #6
10' Camaro SC
Did you take pics of them making contact?
Old 04-23-2016, 12:37 PM   #7
p.s.
I don't even need to. I recently needed to drill an older set of struts (2010) in order for them to fit my 2014 sways. Its a significantly larger hole, i think they went from a 14mm to an 18mm. I could take a pic of the difference between the two since both are off my car. I would be interested to know if i could run smaller links. Not ideal but might be better than drilling.
Old 04-24-2016, 06:45 PM   #8
p.s.
Thinking out loud but what if if grabbed these?:
http://www.ebay.com/itm/Front-Stabil...hW6AFT&vxp=mtr
They look like they come with a washer that would allow them to work with the larger bar? I'm not sure.
Old 04-24-2016, 08:09 PM   #9
Mike_G
Drives: 2010 2SS/RS
Went for 10mm stud to 12mm stud. Looks a lot bigger but it is only 2mm. I have drilled out a few struts to accommodate the newer sway bars with no issues.
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 04-26-2016, 11:20 AM   #10
p.s.
Yes, exactly. I'm working with kw right now and I'm waiting to see what they officially recommend. Odd thing is they sent me install instructions that originally planned on utilizing a bushing to accommodate both 10 and 12mm setups but mine doesn't have that design.
Old 04-27-2016, 11:04 PM   #11
10' Camaro SC
Any chance you could post a pic of the coilover set? Can't find any real images online. Thanks man
