04-11-2013, 07:51 PM | #1 |
Drives: IOM ZL1 Join Date: Jul 2012
Hawk ceramic pads
Question for those of you that have switched to Hawk ceramics. Looks like the fronts on the ZL1 do not have shims but the rears look like they have them. Do you use the stock ones for the rear on the Hawks? Thanks
04-11-2013, 09:01 PM | #2 |
Deep Sea
Drives: 2012 Camaro ZL1 Join Date: Sep 2011
Shims?
04-12-2013, 11:10 AM | #3 |
709 RWHP & 677 RWTQ
Drives: 13' HPE 800 ZL1..... IOM vert, M6 Join Date: Feb 2013
Good question, I didn't put the shim in with the new pads. Should I go back in and add the shim?
04-12-2013, 01:14 PM | #4 |
Deep Sea
No noise from pads, thanks for the info.
04-12-2013, 05:44 PM | #5 |
Called Hawk
R&D guy said for the fronts just apply the supplied high temp grease where the three caliper pistons hit the back of the metal plate on the pad. Grease the pins also. For the rear he said don't use the OE shimes just use what comes on the Hawk pad. Again apply grease to the two areas on the back of the pad where the caliper pistons hit it. Apply grease to the two pins. Very important to use 130 grit sandpaper and lightly sand rotors then use brake cleaner to get the film and filings off the rotor. Make sure rotors are cleaned good. Hope this helps all you Hawk pad fans.
04-12-2013, 06:35 PM | #6 |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
are the hawk pads less prone to brake dust on the rims?
04-12-2013, 07:05 PM | #7 | |
709 RWHP & 677 RWTQ
04-12-2013, 07:07 PM | #8 |
709 RWHP & 677 RWTQ
04-12-2013, 07:11 PM | #9 |
Muscle Maniac
Drives: 2012 Camaro ZL1 CRT Join Date: Nov 2009
First mod was Hawk Ceramics 1 year ago..dust is incredibly reduced and what dust you will expierence is light tan color. Extended the detail frequency dumping the OEM pads. I don't track mine......yet......but the Hawk Ceramics shut it down real quick from 140 mph I can tell you
MasterChief BT
USN (Retired) 2012 Camaro ZL-1 CRT VIN 2G1FJ1EPXC9800357/Arrived 4-21-2012 Reliable Chevrolet Richardson, Texas Life is GOOD ! |
04-13-2013, 07:00 AM | #10 |
so they stop better and less dust? how do they compare in cost to the factory set? my black rims usually look dark brown in 2 days from the factory pads dust.
04-13-2013, 07:45 AM | #11 |
709 RWHP & 677 RWTQ
I wouldn't say they stop better, they perform almost as good. Unless your hard core on a track I don't think you would notice. I paid 240 for the two sets, I know some have paid less. Less dust is an understatement, my car was covered with black dust, now as stated above, little dust and a light color not black!
04-13-2013, 11:37 PM | #12 | |
04-14-2013, 04:46 AM | #13 |
Drives: 2013 red Lingenfelter ZL1 Join Date: Apr 2012
Ceramic pads do not stop better than OEM.
