03-09-2014, 12:52 AM | #1 |
Drives: 2013 2LT RS Join Date: Jul 2013
Installing Solo Cats/Cat Back?
Hey guys,
Quick question but in the near future I plan on ordering Solo high flow cats and their cat back exhaust and am very excited! I was wondering if anyone on here has had experience installing it themselves? It's getting shipped to Germany and isn't exactly easy or cheap to get car stuff over here so does the kit come with everything needed to do a direct bolt on install? I wont need any extra clamps, hangers, etc? I just want to be sure I have everything needed start to finish before I go dropping the old exhaust! Thanks so much guys, -Aaron
03-09-2014, 04:01 AM | #2 |
I know the cats come with everything you need asides from tools.
They are direct bolt on so all you need is the correct socket and a extension helps. Also an o2 socket. I would recommend spraying the o2 sensors with PB blaster and letting them soak over night so that the sensors come out easily. Me personally, I wouldn't waste your time disconnecting the o2 sensors from the connectors. Up to you. A local shop (who knows what they are doing) didn't remove mine and I have not had a single problem. Not sure why everyone says to do that (it could be important but I myself didn't have any issues). Only reason I didn't do it myself was because I didn't have the necessary stuff to do it. Jack, stands, etc. As far as the cat back, I am assuming it comes with everything you need. Should be a direct bolt on to the cats and should be very easy. Easier than the cats
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
03-09-2014, 05:46 AM | #3 |
Awesome thanks! I'm just trying to get all the info I can before starting! What's this about the O2 sensor? People take them off completely or...?
03-09-2014, 07:38 PM | #4 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
The Solo HFCs and Cat back system are COMPLETE, you just need the tools. I did unplug my sensors to be safe and not take a chance of braking any wires in their harness as you spin them out and in. Everything goes together very nice. I had the HFCS on for about 1.5 years before doing the Cat back system. In closing thanks for the service you provide by keeping others serving out of harms way.
03-09-2014, 07:56 PM | #5 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
I bought new Manifold gaskets, cheap. around 10 bucks total.. I don't like to reuse old gaskets. The OE are metal, but do crush to seal. You can do it on jack stands, I have. The right side is tough, a little crowded, the Drivers side is easy. Don't worry if the nut comes off with the manifold stud, just remove the nut after you have it free and install back into the head. get some antisieze that is safe for O2 sensors and lightly coat the threads and do not overtighten.. Have fun and enjoy the exhaust..
03-10-2014, 01:23 PM | #6 |
Go Gators!
Drives: Camaro Jeep Abarth 944 325i Join Date: Jan 2013
My short list includes a ratchet, breaker bar, metric sockets (swivel sockets are a plus), metric wrenches (ratchet wrenches are another plus), an O2 socket, a low profile jack (or a way to get the car lifted high enough to slip a normal jack underneath), four jack stands (to be safe), some liquid penetrant, and some safety glasses (so the penetrant doesn't drip into your eyes, haha)!
Oh... and a buddy to help you out and also hand you your beer while working. With those tools you can most certainly do it yourself! As mentioned the passenger side is a bit more snug when you remove the exhaust manifold nuts/studs (whichever comes off).
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts Engine Mods: All bolt ons (haha) Brake Mods: Brembo SS caliper swap front and rear |
03-10-2014, 01:36 PM | #7 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
i am surprised that the exhaust is still 2.25". I would have thought they would have offered 2.5" like most of the competition.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
03-10-2014, 06:28 PM | #8 |
Guest
Drives: bbbbbb Join Date: Dec 2012
As everyone mentioned the passenger is a tight one. I am a big person and it was a little too tight for me and I ended up paying a mechanic that had a hoist to install them for me. I can only suggest you do the passenger side first since that is the toughest before dong the drivers side.
Dean. |
03-10-2014, 09:14 PM | #9 |
Drives: 2013 Camaro RS 1LT, 6M Join Date: Jan 2013
Important, don,t forget to disconnect the battery before you start. :-D. Starter cable is right next to the cats. Ask me how I know.=-O
03-10-2014, 09:23 PM | #10 |
Guide I made (sorry for the lack of photos but steps you through the process) http://www.camaro5.com/forums/showthread.php?t=344024
