Old 08-29-2020, 07:54 AM   #1
Inferno dogg
Inferno dogg's Avatar
Drives: 2010 Camaro 2SS
My numbers are garbage!!!
So this was a huge disappointment. Dynn Jet with all my mods seems so low!!! What are you all getting with similar mods?
GPI SS3 cam with top end goodies,Circle D 4c 3800 w/Derale trans cooler kit sold by GPI,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Andrews Auto Georgetown MI, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit
Inferno dogg is offline   Reply With Quote
Old 08-29-2020, 08:17 AM   #2
Warship2k15
Ok I really don’t know where you are expecting big gains from.The automatic equipped cars usually dyno at 330-350 RWHP.You should have a small increase in hp from the headers and tune maybe 20-40hp.and that’s kinda what you are getting.
Everything else is going to make it quicker and more fun to drive but will have zero affects on hp.
Warship2k15 is offline   Reply With Quote
Old 08-29-2020, 08:18 AM   #3
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I'm not that familiar with automatics but that torque curve is falling off more than I would expect. Did your tuner have other files to compare against?
Sent from my Pixel XL using Tapatalk
Old 08-29-2020, 08:20 AM   #4
byrds8
byrds8's Avatar
Drives: 2013 Camaro 2SS, L99
Aren't the biggest mods you have the LTs and CAI? Granted if its an L99 I would have expected a bit more than that but not greatly more. I think a lot are saying 370-375 with LTHs and a tune.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
byrds8 is offline   Reply With Quote
Old 08-29-2020, 08:31 AM   #5
Inferno dogg
Hmm maybe I am reading way to many posts on the internet lol . Unfortunately the tuner is so busy I'm sure he threw it on tuned it and yelled NEXT. Plus there building is locked down because of covid .
Old 08-29-2020, 08:36 AM   #6
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
Agreed 100%. The L99 starts at 400hp crank and considering ~15% driveline loss, that puts him at 340RWHP. LT's, a tune and a CAI are not going to gain much. I'd say those numbers are solid for what you have, OP.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 08-29-2020, 08:55 AM   #7
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
what would you expect with only bolt ons? plus do you really car about dyno numbers? all they are is a guide line to see if you are getting any gains from adding any mods....and that is mostly only true if every time you dyno, you are using the same dyno in the same conditions.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 08-29-2020, 09:31 AM   #8
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Those numbers seem to be on par for an auto with long tubes and a CAI. Time for heads and cam...
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 08-29-2020, 10:51 AM   #9
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
My 2013 2ss/rs L99 dyno tested at around the 330 to 350 hp. What would one have to do to realize a larger gain in HP? A cam for example? I do also own the 1987 Grand National. Performance gains are easy for this car. A chip, K&N filter, gutted cat, and a stiffer valve spring gets about 175 rwh and dropped the 1/4 mile time from the stock 14.5 to 13.2. I believe the last 2 times for my stock Camaro were also 13.2. It is interesting what a stock factory turbo to do to a 3.8L V-6. So now I wonder what simple and not too expensive mods could be made to move the Camaro into the 12s?
BuddyLee is offline   Reply With Quote
Old 08-29-2020, 10:53 AM   #10
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I'm more concerned about your torque drop off.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 08-29-2020, 12:51 PM   #11
DRKS1D3
DRKS1D3's Avatar
Boosted engines make big power with very simple mods, so your GN doesn't surprise me. For example, an SS may gain 6-8hp from an intake, but a ZL1 can gain 25+hp.
As far as getting your stock SS from a 13.2 to a 12.9...LT headers (obviously w/ a tune), intake and an X-pipe should do the trick. If you really want to get it done, add a cam in there. My SS (LS3) put down 455hp w/ BBK shorties, JBA HF cats, FM axleback, K&N intake, Lunati cam and a tune.
Old 08-29-2020, 12:58 PM   #12
TheFlyingBananaSS
I got mine into mid 12's with gears, cai, trailing arms, 3" cat back, launch practice, and a tune.
Old 08-29-2020, 01:00 PM   #13
TheFlyingBananaSS
But mines a factory freak. It's beating stock 5.0 coyotes, even with a passenger. I also drive it like I stole it from day 1 and never had a single issue except rear brake light.
Old 08-29-2020, 01:53 PM   #14
gm2376
gm2376's Avatar
and that is all that matters...the dyno is just a tool....what matters is what is does going from a to b if you are adding hp.
