01-14-2010, 07:27 PM | #1 |
Drives: 2LT/RS Join Date: Aug 2009
Front plate attach
Figured I better attach a front plate before I got caught. I used a couple pieces of aluminum flatbar $3 connected to the two bolts underneath the bumper.
I don't like it, but at least there is no holes. |
01-14-2010, 07:33 PM | #2 |
Nice job.
01-14-2010, 08:57 PM | #3 |
that's great, and cheap
Frank
(Drive Safely & Responsibly) |
01-14-2010, 09:15 PM | #4 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
How does that not flutter shake and wobble at speed? I don't think that flat stock is going to be very supportive given the length from the attatch point all the way to the plate bracket. How long is that? 10-12 inches?
Let us know how it holds up.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
01-14-2010, 10:58 PM | #5 |
Drives: NSMNJW=2010 CGM 2SS/RS LS3 Join Date: Dec 2009
Ya It looks like you should bend another piece of flat bar with a hook on it at the top so you'd hook it on top then bolt it to the bottom.Use sticky back thin foam to line the hook and protect your paint. I think it'll vibrate with out it.
GJ thou,right idea |
01-14-2010, 11:03 PM | #6 |
#42,288
I am taking my chances, even though in Idaho a front plate is required. I feel like rebel, at least until I get my first ticket.
Darren |
01-15-2010, 01:16 AM | #7 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
hey i have it mounted in the same place, but i just flipped the mount upside down, drilled a few holes and zip tied it to the front bumper. Looks the exact same, cant see the zip ties and everyone thinks its bolted. It looks great and hasnt budged since i installed it in June.
Great job on the mount |
01-15-2010, 03:41 PM | #8 |
Drives: 1LT|RS|SIM|M6|BA Stereo Join Date: Jul 2009
does the metal part rub on the fascia tho?
1LT | RS | M6 | SIM | BA Stereo 1000 - [07-23-2009] Order Made at dealer 1100 - [08-04-2009] Preliminary order accepted 2000 - [08-25-2009] Accepted by GM 3000 - [09-01-2009] Accepted by production control TPW = 10-05-2009 3300 - [09-28-2009] Scheduled for production 3400 - [10-01-2009] Broadcast - Being Built 3800 - [10-13-2009] Produced - Built- VIN 2G1xxx54917 4200 - [10-19-2009] Shipped 5000 - [10-19-2009] Delivered to the dealer 6000 - [10-20-2009] Delivered to the customer |
01-15-2010, 09:24 PM | #9 |
It is 9.5 inchs between the holes I drilled in flatbar.
The plate holder sits just under .5 inch from fascia. Put two thin strips of rubber at 2 attach points under fascia. Put a 2x3 x5/8 piece highdensity foam... centre of flatbar on back of plate holder, with 3 contact points it stiffened the holder up considerably. When the weather gets better I will open her up on the highway and test it out. |
01-16-2010, 07:30 AM | #10 |
Drives: 2SS/RS IOM - A.K.A. DA ;) Join Date: Jan 2009
Looks similar to TRM0002's bracket. The only thing I would caution anyone using an alternative mounting option like this is to use some stick-on foam to protect the paint. But, I learned on my truck that you're better to stick the foam to the CAR, rather than the bracket. Reason being is with the wind moving the bracket the foam rubs on the paint. Even the foan will scuff the paint over time, plus road grit gets on the surface of the foam making it worse. You can always clean the glue from the foam off the paint (WD40 or goo gone work) but the scuffing can only be buffed out and only if not too severe. My 2 cents. Learn from my mistakes boys.
"BBOMG - More than just a car show.... It's an experience!" |
01-16-2010, 07:57 AM | #11 | |
Frank
01-16-2010, 05:26 PM | #12 |
nicely done!
too bad holes are drilled to my bumper already at the dealer before I pickup my car. |
01-17-2010, 11:55 PM | #13 |
same here
01-18-2010, 12:17 AM | #14 |
SS/RS
Drives: 2010 SS/RS IOM w/blk stripes A6 Join Date: Jun 2009
http://www.drivingcomfort.com/retrac...late-mount.cfm
Check out this link and you will find this mount for $49.95 |
Similar Threads | ||||
Front License plate Mod. only $8 | lakers171 | USA - California | 13 | 01-08-2012 01:52 AM |
BC Front Plate Mounts | kenni | Canada | 2 | 12-02-2009 11:20 AM |
I have a front plate and it's STILL illegal... | wrek | Cosmetics and Lighting Modification Discussions | 23 | 10-24-2009 11:11 PM |
Mounting the front plate | c0rsa180 | 5th Gen Camaro SS LS LT General Discussions | 12 | 08-13-2009 10:59 AM |
Retractable License Front Plate Holder | formulahawk | Cosmetics and Lighting Modification Discussions | 3 | 06-12-2009 06:30 AM |
