05-31-2014, 02:51 PM | #1 |
Jim
Amount of oil???
Ok I have an LS3, in a lot of threads I have read C5 members state they use 8 1/2 quarts for an oil change. I just changed mine (2013 2SS) the manual states oil and filter change 8 quart. What is the reason for the extra half quart? I started the car to circulate the oil so I'm waiting for the oil to settle to check the level.
"I'm that one shot one kill bringer of fate"
05-31-2014, 03:40 PM | #2 |
Camaro owner since 1982
Drives: 2012 Camaro 2SS-RS Conv IBM L99 Join Date: Jul 2009
8 quarts is enough.
2012 Camaro RS-SS Conv IBM, L99
1968 Camaro RS Coupe 327 AT 1968 Camaro RS-SS Conv, sold 1993 |
05-31-2014, 05:49 PM | #3 |
Jim
05-31-2014, 11:31 PM | #4 |
Drives: "Looking for" SS Camaro Join Date: Feb 2014
I would say the half quart comes from guys filling up the filter before putting it on. I would always recommend filling your filter with oil before putting in on to prevent a "dry start" after you change your oil.
But the poster above is correct....8 quarts is enough |
06-13-2014, 09:42 PM | #5 |
Drives: 2014 ZL1 Join Date: Sep 2012
I put 8 quarts in mine, but didn't like it showing a half quart low on the dipstick, so I added the half quart so it was at the full mark. My thought is, gm put the marks on the dipstick for a reason.
06-14-2014, 06:35 AM | #6 |
Drives: bicycle Join Date: Jun 2014
The filter wicks in a little oil, depending on the type/size filter it can be close to 1/2 quart. Of course this includes what stays inside the bypass area all the time.
06-14-2014, 07:56 AM | #7 |
Drives: camaro Join Date: Jun 2014
06-15-2014, 06:57 PM | #8 |
Let's go Rangers!
Amount of oil???
I as well as many other run 7.5qts, do a search. These engines (LS3 & L99) like to run a bit low and even run a bit quieter, especially the L99's. 8.5qts is TOO much. The most I would put is 8 (capacity) but as you can see I won't even go that much.
06-15-2014, 07:01 PM | #9 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
The oil capacity of the L99 is 8 qts not 8.5
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
06-25-2014, 06:19 AM | #10 |
Book says 8.0 qts. I use 8.0 qts. And I do fill the filter about 3/4 full before installing.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
