10-04-2010, 06:13 PM | #1 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
3.4 pulley without meth safe?
I was just wondering what you guys think about running a 3.4 pulley on a maggie without meth? If you tune safely would it be ok? Just worried about the coating on the rotors with the meth that I've been hearing about on here. I would prefer to run meth but not if it's going to screw up my blower. Any advice will be appreciated or any other solutions. I am currently running a 3.6 pulley, ADM stage 2 cam, and Stainless Works headers and full exhaust LS3. Thanks guys for the help and info.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
10-04-2010, 06:19 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
I'd be careful. You're are on the boderline with running out of fuel so either go with meth or a fuel upgrade i.e. bap or new pump etc.
10-04-2010, 06:25 PM | #3 |
Sorry forgot to mention I am running the ADM fuel system as well.
MODS:
10-04-2010, 07:19 PM | #4 |
In that case I think you're gd to go, but don't quote me. As long as you have the fuel then you should be fine. In your case the meth would be added insurance if you choose to use it, doesn't seem like you are. Maybe just ask Ted or even Andy and they can give you the concrete answer. Gd luck!
10-04-2010, 07:43 PM | #5 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
How much boost and what are your IAT's now? What are your power goals? If you can get away without it, I wouldn't fool with it. One less thing to have to keep track of. I'm at 8.5psi and IAT's run a max of 35 to 40 degrees over ambient. RWHP is well over 650. I don't have meth and don't plan on getting it. My LS3 has been running that way for about a year and a half and about 15K miles.
10-04-2010, 09:44 PM | #6 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
Meth was not recommended by maggie rep for their s/c! Sounds liek you should have the fuel to support it with the adm setup however belt slippage might be another story which requires an upgrade a pretty price.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
10-05-2010, 05:28 AM | #7 |
Thanks for all the info guys. Don't know what my IATs are yet not been to the dyno(was waiting to see about the meth) but my goal is 600 RWHP. I am also looking into the 8 rib system as well.
MODS:
10-05-2010, 08:03 AM | #8 |
Okie doke
With the fuel system, you'll be fine .. I'm only running a BAP and I have the 3.4 pulley and only his stage 1 cam ..
Crowley
10-05-2010, 09:37 AM | #9 |
Drives: 625 rwhp red jewel ss COTW 11-8-10 Join Date: Oct 2009
I'm running the BAP with the Stage 2.5 cam and everything is fine!
10-05-2010, 12:30 PM | #10 |
You can run a 3.4 with a cam on 93 octane pump gas but not without a cam, the boost would be too high for pump gas.
Hope this helps. Ted.
www.jannettyracing.com
10-05-2010, 12:47 PM | #11 |
Drives: 2010 2ss/rs, 2004 pontiac gto Join Date: May 2009
With the list of mods you have. You're good to go with the smaller pulley. However I think you'll find out you'll get belt slippage in higher RPM. You'll at the very least need to source a smaller belt for that pulley.
10-05-2010, 03:29 PM | #12 |
I appreciate all of you for the good info and replies. I may go ahead a swap the 3.6 for the 3.4 now. Just trying to research before hand and tune one time. Probably upgrade to an 8rib or cog drive also when funds are replenished. Where do you get your pulleys from? Thanks again to all of you!!!
MODS:
10-05-2010, 03:54 PM | #13 |
Drives: 1999 Trans Am Join Date: Jul 2009
Are you maxed out tune wise on the 3.6" pulley? Sometimes if the car likes a few more degree's timing you might get a good gain.
10-05-2010, 04:39 PM | #14 | |
Ted.
Similar Threads | ||||
DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 08:25 PM |
3.4 pulley, coolingmist kit, fesler pod...... | ddavis | Forced Induction | 7 | 09-24-2010 09:25 AM |
Quick question on tvs pulleys | boostedyards86 | Forced Induction - V8 | 19 | 04-29-2010 09:04 AM |
maggie pulleys/boost | drkllr | Forced Induction - V8 | 16 | 03-24-2010 06:00 PM |
tune a maggie with meth and 91 octane gasoline | Carlos Garza | Tuning / Diagnostics -- engine and transmission | 13 | 03-21-2010 12:16 PM |
