12-09-2009, 05:06 PM | #1 |
Drives: Camaro 2010 SIM Join Date: Nov 2008
Slightly smaller diameter tires a problem?
Lookin' at putting 275/45/18's on all 4 corners. These are 27.7 in diameter compared to the stock 28.6 in...Anyone know if this will mess with the ABS, traction control, etc.?
I expect my speedo/odometer would be off by 3%. |
12-09-2009, 05:53 PM | #2 |
Drives: 2010 Join Date: Jul 2009
based on that tize when your speedo read 60MPH
your Speed is actually 58.1 Mph This is a good website, sometime it takes a minute to load up. http://www.miata.net/garage/tirecalc.html |
12-09-2009, 06:28 PM | #3 |
Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
, You are correct that speedo, traction control, stabilitrack, and ABS will all be affected. However, you may be able to do a tune that will compensate for all of the abvove. Not sure what the purpose of changing sizes is about, looks or performance, etc. Tell us what your goal is, autocross roadrace??
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
12-09-2009, 06:41 PM | #4 |
Drives: Corvette ZO6 CSR edition #47 Join Date: Apr 2009
I want to go to the 18" setup for roadracing. Tires are impossible to get in the 20 inch. I have yet to find a 18" rim that will work without spacers.
Nationwide Turf
"artificial turf factory" |
12-09-2009, 11:09 PM | #5 | |
12-10-2009, 08:25 AM | #6 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
Shorter tires will improve your effective gear ratio slightly, but not anything substantial. Also, a shorter tire will not only read a higher speedometer number, it will also put more miles on your odometer than you are really driving.
Fquick.com/NineBall
Similar Threads | ||||
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow | KILLER74Z28 | General Automotive + Other Cars Discussion | 25 | 07-22-2011 10:51 AM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
Winter tires & wheels for RS Camaro, smaller size then 20 inch mess up the odometer? | ladysman07 | Wheels and Tires Talk Sponsored by The Tire Rack | 5 | 09-08-2009 03:57 PM |
Wheelie Possible? | Dentyneice | Dragstrip and Launch Techniques Discussion | 34 | 06-12-2009 11:30 AM |
18, 19, & 20" replacement tires ... | dougmac | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 03-29-2009 05:27 PM |
