11-02-2012, 07:50 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Aug 2009
DSS aluminum 1000 hp driveshaft
This is a M6 DSS 1000 hp driveshaft that i had on my car about 1500 miles. I am replacing my current setup with 9" so no longer need this. I hand polished the shaft but it does have a ring around it towards rear where my parking brake cable came unclipped and rubbed. Will sell for 650 shipped.
11-02-2012, 07:55 PM | #2 |
Is this for automatic or manual?
11-02-2012, 08:27 PM | #3 |
This is for M6, thanks i forgot to put that.... Listing has been modified
11-02-2012, 09:27 PM | #4 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
If I can get back on my feet from this hurricane I may be interested.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
11-02-2012, 09:35 PM | #5 |
Sounds good, hopefully things go well for you
11-03-2012, 08:03 AM | #6 |
Pm sent
2012 Camaro SS, CAI,VMax TB,LT ARH, HF Cats,Borla Type-S,LPE3.70 Gears, If I can't eat it, bet on it, or bang it I probably don't have the phone number!!!!! |
11-03-2012, 05:25 PM | #7 |
Sold to camper. Thanks
11-03-2012, 05:54 PM | #8 |
Banned
Drives: 10' 2SS LS3 M6 Join Date: May 2012
Thanks bud, look forward to getting it!
