09-13-2014, 05:56 PM | #1 |
Drives: 2013 ZL1 Convertible Join Date: Aug 2014
E85
Can I start running e85 in my car or do I need a tune ? Not sure if the stock injectors or fuel pump can handle it. The best fuel we have here is 91 Octane otherwise, and from what I hear, e85 will also help with heatsoak.
I have a rotofab on now, but will be installing a 9.55 or 10" lower along with ID850's and a tune next summer. |
09-13-2014, 07:34 PM | #2 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
You need to tune for E85...
09-13-2014, 08:50 PM | #3 |
Adm performance did a write up on e85 in a zl1. They had there own setup for this. Do a search on it. Made awesome power. Just search adm zl1 e85 test.
09-13-2014, 09:37 PM | #4 |
Drives: none Join Date: Aug 2011
On a stock car, the injectors and pump should be fine with E85. You should still datalog or put the car on a dyno to verify.
But no, E85 doesn't affect heatsoak at all. Modded....needs a tune and more pump. |
09-13-2014, 11:17 PM | #5 |
With the mods, would the boost pump work, or would the original need to be replaced ?
09-14-2014, 09:11 AM | #6 |
I'm thinking replaced. Almost positive of it.
Here's the thread that smokum was referring to: http://www.camaro5.com/forums/showthread.php?t=274664 Andy should be able to help you with getting the right parts to go E85 on your ZL1. |
09-14-2014, 11:25 AM | #7 | |
09-14-2014, 01:20 PM | #8 | |
12-12-2015, 12:08 PM | #9 |
Drives: CAMARO CONVERTIBLE L99 2012 Join Date: Aug 2014
Attached trends of french ZL1 Flex fuel E85.
+73HP / +52NM. I'm looking for the best type of sparks to be used with E85 ? Is spark iridium type mandatory in ZL1 with E85 ? |
12-12-2015, 03:52 PM | #10 |
There is e85 all over dallas now. ADM did my e85 conversion back in October.
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80 “1360 Rwhp 1225 Rwtq 25 lbs of boost” |
12-12-2015, 04:29 PM | #11 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
Stock injectors won't work for long because the ethanol will corrode them. Whatever injector you decide to go with make sure it has stainless steel inners. Any Injector Dynamics model will have S.S inners
Stock pump will be fine up to low-mid 600whp on e85, then it will need a BAP or complete upgrade
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
12-12-2015, 04:35 PM | #12 |
Every car and dyno is different, so don't expect 70hp gains like above. It is possible but I've seen 30-50hp gain more often.
Ex: My car only picked up 26hp but picked up tons of torque everywhere in the power band, +40tq in some areas
12-13-2015, 03:26 AM | #13 | |
ZL1 crystal RED
Drives: ZL1 2014 Join Date: Oct 2013
thank you for your contribution. to be sure: what's a BAP? Thanks!!!!!
12-13-2015, 06:49 PM | #14 |
Drives: 2014 ZL1 Join Date: Jun 2014
