06-18-2011, 12:05 PM | #1 |
Drives: 2010 Camaro Join Date: Jun 2011
NEED HELP on complete vvt/dod/afm delete
Hi guys and thanks in advance for any help I just did a complete Dod and vvt delete and installed my new cam and the whole delete kit so
Question 1: On the original L99 valley cover there is a sensor in the rear that has no where to connect with the new ls3 valley cover? what do you do with the connector? and #2 there is a two wire connector that was going to the dod on the front cam cover, this too has no where to connect and I am getting a cam sensor code after it ran fine for a couple minutes while beginning the tune then started to run bad and stall with the P0010 code for the cam sensor continuesly coming up? I am a new member and will fill out my info latter today. Thanx.. |
06-18-2011, 02:36 PM | #2 |
Drives: 2SS RS A6/ CTS-V A6 LSA Join Date: Mar 2010
Go to Horsepower sales.
in pompano......its expensive but worth it. hell man why didn't you buy an ls3 magnacharging the L99 witout a cam change can yeild upto 600 rwhp with traction a big issue....i don't see the need. but good luck....i also did the afm dod delete.....just to remove the mechanicals.. tranfring to a cam is a labor intensive deal
10 2SS(7Psi)/10 CTS-V(9Psi)
L99, ADM RACE CAI, TVS 2300,LG- Headers and X pipe ,catless 3 inch back w/Magnaflows , Ngk plugs,Msd wires,180 stat,Springs ( lowered 1"- looks solidly correct)Sways and endlinks,BMR trailing arms, Slotted rotors and Hawk HPS ,tuned ,Black out bowtie and custom (black)"SS" on sides /midnight rims (8psi) 2010 Raven (triple black.)CTS-v , crank pulley, Bubb CAI , AR Headers, custom catlessback. magnaflows. tune ( 9psi) former LS7, LS2 and LS1 owner.(Zo6, GTO's, WS6) |
06-18-2011, 03:12 PM | #3 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
I agree w/napper. Were in Palmetto/Bradenton....where are you located?
06-18-2011, 03:17 PM | #4 |
Thanks bro... just need those 2 answers during the weekend..and I will be back on track
06-18-2011, 03:19 PM | #5 |
Just by the Georgia border in Jacksonville
06-18-2011, 04:16 PM | #6 |
Drives: '04vette- '11-1SS '11-1LS(wifes) Join Date: Feb 2011
Is there a sticky thread with a step by step on how to tune out the AFM?
I did a search but was unable to find anything. Thanks.
Magnaflow catback - CAI - Foose Legend rims
06-18-2011, 05:28 PM | #7 |
There is no link attatched??
Thanks for trying to search . I have searched too.. Dod is shut down in Hp tuners but there is nothing I saw for AFM and I still need to know what to do with the harness from the old/L99 valley cover and the 2 wire connector that went on the cam cover from the dod i guess...??? |
06-18-2011, 09:40 PM | #8 |
The connector for the AFM can be zip tied to the harness for the injectors and coils. It is no longer used.
For my customers that do a LS3 conversion I change the front cover and install a newm3 wire short harness to the crank sensor. HP tuners can turn off the AFM and the associated codes. |
06-19-2011, 02:36 PM | #9 |
Thanks,
So then neither the 2 pin connector at the timing cover or the 4 pin at the back of the intake are connected any longer. Then why am I getting the p0010 code for Cam sensor?? maybee it just went bad? It ran idled fine for a couple minutes then backing up to the dyno it started sputtering and stalling and running rough with the p0010 code continuesly comming on . and runs rough every time you start it now . only 6 K on the car |
06-26-2011, 05:25 AM | #10 |
Cool SS
Drives: 2010 ABM Camaro SS/RS Join Date: Sep 2009
I'm in the midst of doing the DOD/AFM delete on the L99. The Valley cover LS3 replacement has a metal tube coming out of one end, which the L99 did not have.
What goes on this tube? It looks like some sort of vent tube. |
Thread Tools | |
Similar Threads | ||||
FS: bowtie delete, stock bowties(and mount), and stock grille | mjbreese | Exterior Parts & Accessories | 7 | 01-13-2012 01:42 AM |
F/S Drake Bowtie Delete | seasick | Exterior Parts & Accessories | 5 | 06-05-2011 01:35 PM |
Thinking off doing muffler delete. Thoughts | CamaroC-17 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 17 | 05-20-2011 10:54 AM |
Kook's Complete System | LibLoather | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 34 | 05-10-2010 08:40 PM |
ProCharger Supercharger Complete Kits With Tuning Shipping Soon! | tbyrne | Forced Induction | 0 | 08-14-2009 12:27 PM |
