12-30-2017, 10:42 PM | #1 |
Drives: o Join Date: Jun 2017
Starting to make progress
What better place to be when the weather outside is so freakin cold!
Really like my new heater. Outside its below zero. In my garage its 65 to 70 degres. Cant wait to fire her up! Gettin there |
12-30-2017, 10:59 PM | #2 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
What's she gonna be when she grows up?
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
12-30-2017, 11:07 PM | #3 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
That’s awesome brother.
"Make yourself sheep and the wolves will eat you"
12-30-2017, 11:17 PM | #4 |
418 all forged internals. 11.5 to 1 compression. Livernois stage 2C high lift cam. Livernois L92 power storm race series heads.
Naturally aspirated. I'm hoping to get 600 + crank shaft Hp on 93 octane pump gas. |
12-31-2017, 06:05 AM | #5 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
GET'R Done. |
12-31-2017, 07:11 AM | #6 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
Awesome! I love NA builds. Good luck
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
12-31-2017, 09:37 AM | #7 |
Drives: 2010 2ss RS. White (RIP) 2012 LS3 Join Date: Sep 2011
I wish I had a garage that was heated to do things in. And part of me wishes my engine would blow up just so I can go 418 stroker all forged. I know it’s more expensive than supercharged, but something about getting as much freaking power as I can NA really excites me more Than it probbaly should.
12-31-2017, 11:43 AM | #8 |
I wanted to go NA because it seems like everyone is running blowers and turbos these days. The suspension isn't really ready for FI anyway.
After I get this up and running I've got a lot of things I need to up grade in the drive line and reinforcing the suspension. Maybe after that she'll be ready to try some FI. I have another LS3 block and who knows down the road. If I could win the lotto it would sure make this stuff easier. |
12-31-2017, 12:07 PM | #9 |
I like it... subscribed and waiting to see more as you progress!
Car mods: never enough!
12-31-2017, 01:30 PM | #10 |
Resident nomad
That's an awesome build! I know what you mean about suspension being ready. Even after a short drive after the install of my LSA, I notice the added weight on the front end. Glad I installed the adjustable CO's first....
Sold:
01-04-2018, 01:48 PM | #11 |
Drives: 2010 Camaro 454 LSX (SOLD) Join Date: Jun 2013
Looking great!
01-05-2018, 10:43 AM | #12 |
New clutch arrived. I went with the Lingenfelter ZR1 twin disk and steel flywheel kit.
It comes with new actuator and a spacer that allows it to fit the gen 5 camaro. This set up was highly recommended to me for ease of fit, drive ability, and clamping strength. I decided to just keep with the stock bleeder. The remote bleeder would probably be convenient but I don't really need it. Crawling underneath to bleed it isn't that difficult. I have a set of the prothane motor mounts coming should be here next week. I'll have the clutch mounted today. Cleaning the engine bay and polishing aluminum parts so as soon as the mounts get here she's ready to start going back together. Next thing on my mind is what I'm going to do with the IRS. The OE drive shaft needs a new carrier. I don't have enough funds to completely upgrade the IRS like I would like to. I'm thinking at this time, rather than put a new carrier on the OE shaft, I might go with a one piece aluminum drive shaft. Next question is CV joints or U-joints? Ahh decisions decisions |
01-05-2018, 01:41 PM | #13 |
Are you doing this build yourself Gasoholic?
01-05-2018, 07:04 PM | #14 |
Livernois did the heads and block. I'm putting everything else together.
Once I get it running I'm going to have Livernois do the tuning. |
