04-21-2012, 03:13 PM | #1 |
Enthusiast
Drives: Camaro SS | e92 M3 Join Date: Apr 2012
OEM Bolt Pattern - set the record straight!
So I've been looking into adding spacers... I've already read all the "stigma" these things get but I have spacers on my M3 and it performs beautify. That said, I'm looking at two brands, H&R and Eibach.
H&R says the 2010-2012 Camaro uses 5x120. However, the Eibach equivalent part number that fits the same car/year states the bolt pattern is 5x120.65 What gives? Who is right? |
04-21-2012, 03:29 PM | #2 |
Quit being a pu$$y
5x120
04-21-2012, 03:36 PM | #3 |
2010 SIM Beige RS 6M
Drives: SIM RS 6M 66 Corvair Silverado LTZ Join Date: Oct 2008
Good stuff in the owners manual.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America |
04-21-2012, 07:37 PM | #4 |
Enthusiast
I have an e92 M3. It's 414bhp V8 and comparatively accelerates quicker than the camaro due to the short geared 6speed tranny. Ironically, I get better gas mileage from the Camaro. From a weight standpiont, yes, I think the Camaro is heavier...
04-21-2012, 07:38 PM | #5 |
Enthusiast
aaaahhh! Didn't even think of that... joke is on me. It just puzzled me that Eibach would advertise theirs for the 2010-2012 Camaro being that theirs is 5x120.65
04-24-2012, 08:45 AM | #6 | |
Drives: 2010 1SS Join Date: Jan 2010
As for spacers, they are not the best idea, especially on a heavy car, but consider that the 5th gen has huge 14mm studs and it doesn't seem as bad. Before the aftermarket wheel companies came out with drag wheels, everyone was running OE Z06 wheels with a spacer. We ran 10.50's all year long with this setup and had no issues whatsoever. We don't recommend it but there are a lot of people already doing it without issue, just stay conservative on the thickness and you will probably be fine. |
04-24-2012, 02:42 PM | #7 | |
Enthusiast
Thanks! This is very informative. I went with H&Rs 25mm all around. This is not a track car nor do I plan or racing it... it's my daily. Thanks again. |
05-17-2013, 04:08 PM | #8 |
Can't stop ***ifying
That car is better that the Camaro. I had a 2009 dct m3, I now gave a 2013 ZL1. I was expecting a performance improvement with 580 HP. But they felt the same . I looked it up, MP3 has same 0 to 60, same 1/4 mile, same top speed, and that dct was godly. So an e92 MP3 would make short work of an as Camaro with ease (on the street)
Rotofab, grinding rear diff sound forever, dealer replaced supercharger - now i have a rattle when starting from a stop, ordered 2.35 lingenfelter pulley, hp tuner, belt, 100mm idler pulley, tr7IX spark plugs, wideband kit, long tubes with no cats...hoping for 650hp. dyno with rotofab = 518hp |
05-17-2013, 08:05 PM | #9 |
Drives: 2010 summit white 2SS/RS M6 Join Date: Sep 2012
OEM bolt pattern
100 percent 5x120mm !!!measured for myself before I made a pair of 5x5 to5x120mm by 37mm thick hub centric to wheel centric adapters to put these widened to 10-1/2 rears on my 1990 Chevrolet truck!!!
2010 2SS/RS M6,kooks 1-7/8 LT'S with hi flow cats,factory NPP cat back system,ADM performance street c.a.i.ADM built LSA with 750+ package,160 deg. thermostat,mti six shooter shifter,jac fab front license plate bracket and tunnel brace,eibach 1 inch pro kit,ADM exhaust controller,custom ADM performance tune,703 rwhp 704 rwtq
05-17-2013, 08:10 PM | #10 |
OEM bolt pattern
Sorry about the rotate !!!
05-17-2013, 08:14 PM | #11 |
OEM bolt pattern
Rotate again !!!
05-17-2013, 08:45 PM | #12 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
Looks good. Those wheels look familiar.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
05-17-2013, 10:18 PM | #13 |
Thanks yotaman,wheels are sweet.rears fit nice with adapters i made but I gotta do some engineering for the fronts to fit but ill post pics of car and truck side by side!!!
05-18-2013, 01:04 PM | #14 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
Its 5x120 but I am sure the Eibach ones will work as well. They probably designed them that way. H&R Spacers have had a long time excellent reputation for quality. I would go with them.
