05-08-2014, 06:17 PM | #1 |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
TIRE PRESSURES MT DR/ MICHELIN FRONTS
I have 305/35/20 MT DRAG RADIALS AND 295/35/20
MICHELIN PILOT SUPER SPORTS FRONT.ANY SUGGESTIONS FOR A STARTING POINT ON TIRE PRESSURES? I HAVE @560-570 RWHP
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
05-08-2014, 09:14 PM | #2 |
Drives: 2013 ZL1 A6 Join Date: Nov 2013
18-20
05-09-2014, 08:58 AM | #3 |
Drives: Camaro ZL1 Join Date: May 2012
My ET Streets have hooked best at the track when around 20lbs HOT (for me that has been 17lbs cold)
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
05-09-2014, 10:07 AM | #4 |
Drives: none Join Date: Aug 2011
05-09-2014, 10:17 AM | #5 |
Drives: '21 ZLE A10 Join Date: May 2012
try 19 and adjust from there in 1 psi increments. If it hooks, leave it alone...if it doesn't, lower psi by 1 and try again. My buddy in his CTSv runs 16 psi.
05-09-2014, 11:32 AM | #6 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
All of the previous posting pressures are track pressures. On the street I would run them about 32 to 35 cold, the sidewall likes more air on the street.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
05-09-2014, 01:47 PM | #7 | |
Drives: 2018 ZL1 1LE Join Date: Sep 2013
Great advice for the street. I was running 25-28 hot and posting better G-tech Pro 0-60 times than 20 hot... on a closed street. Never tried the 32-35? got me wondering now |
05-09-2014, 05:25 PM | #8 |
ROCK
THANKS I WAS LOOKING FOR PRESSURES AT THE TRACK.
APPRECIATE THE FEEDBACK.
