Old 07-29-2015, 10:03 AM   #1
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
V6 Outboard Mount Rear Sway Bar Available at JPSS
When we designed our sway bars, we paid special attention to the needs of the V6 community. We tucked the ends of our rear sway bar in just enough to clear the banjo bolt on a V6 brake caliper. Our bars are 27mm adjustable front and 32mm rear solid.
This is a 1LE running with JPSS sway bars.
When the 2010 5th Gen was released with the inboard bar, it understeered / pushed badly when driven hard. A smaller front bar with a big rear bar improved the performance, but nothing like the GM engineering change to relocate the sway bar closer to the wheel on the ZL1. If you have upgraded sways, you can replace your rear bar with a JPSS bar and see a huge improvement. If you are on stock V6 bars, installing a JPSS set of bars will be transformational.
JPSS bars for that fit the V6 are in stock ready to ship today. You can read more about JPSS bars for your V6 here: http://www.jpssonline.com/#/jpss-black-magic-sway-bars/
Old 08-05-2015, 12:55 PM   #2
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
Very interested, please provide additional info for front and rear sway bar set up. I dont see pricing on your website!
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 09-26-2015, 09:40 AM   #3
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Already having the pfadt sport setup, the adjustability is all done from the rear.
If I were to add the jpss outboard rear only bar, FIRST...would handling be so extreme as to be unmanageable?
As an example, those who only upgrade the rear at first, but run a stock bar.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 09-26-2015, 09:42 AM   #4
JusticePete
A stock V6 with a square tire setup is an aggressive setup, but not one I would consider unmanageable.
The JPSS 32mm rear with the Pfadt front would bet a really good setup.
Are you square or staggered?
Old 09-26-2015, 02:48 PM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
+1
Old 09-26-2015, 05:02 PM   #6
Drives: 2016 camaro
right now, I am staggered with the 20x8 fronts and the 20x9 rears (245-45-20/275-40-20). in the short future ive been looking to change to 20x9 fronts. but not sure if i'll get to that this year before autox is done.
happy to see a setup where you don't have to change the rear brakes finally!
Old 09-26-2015, 05:04 PM   #7
JusticePete
For AC staggered or square you will be ecstatic! Would a shirt 2XL fit?
Old 09-26-2015, 05:42 PM   #8
Drives: 2016 camaro
sounds good. will be aiming to get it done before the 10th of October.
2x?lol, just messin, but I'm more a 4-5XL type. We usually call it a "Samoan xtra-smedium"
might have to make it down to VA in the future if you all have an open house or something.
Old 09-26-2015, 06:25 PM   #9
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
I'll be buying a set before the end of the year.
Shawno72 is offline   Reply With Quote
Old 09-26-2015, 09:25 PM   #10
JusticePete
or a track day
XXXXXL got it!
