#Camaro6
Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V6 Bolt-Ons & Tunes
AWE Tuning
Old 12-29-2016, 09:11 AM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
6th Gen Camaro V6 Borla Axle-Back Exhaust S-Type 11926
2016-2018 Camaro V6 Borla Axle-Back Exhaust S-Type 119261 $982.99
Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gasses, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds.
Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship.
This high-performance replacement exhaust system includes all parts and hardware required for installation (some factory original parts may be re-used).
Fitment: 2016-2018 Chevrolet Camaro V6
Dual Round Rolled Angle-Cut Lined
2.25" into muffler dual 2.5-2.75" out
This system comes with four tips but does not have the dual mode valves. You may use this system on vehicles that came from the factory with single tips but you must change the rear bumper valance to accommodate the dual tips.
https://www.rpidesigns.com/shop/item...s-type-119261/
RPI Designs is offline   Reply With Quote
Old 10-20-2018, 09:08 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPIDon is offline   Reply With Quote
Old 11-06-2019, 02:36 PM   #3
RPI Designs
