#Camaro6
Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V6 Bolt-Ons & Tunes
Old 11-19-2019, 08:18 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
ACS Splitter for Gen6 Camaro V6 - Get It At PFYC!
ACS T7 Splitter for 2016-2018 Gen6 Camaro V6 and I4
https://www.pfyc.com/CO1023.html
The 2016 2017 2018 Camaro is simply stunning. The ACS T7 Splitter will set it to a new level. Not only will it add an extra visual dimension to the car's sleek build, but it will add aerodynamics and guile at high speed to a vehicle that already handles like a dream.
This composite splitter is durable and functional while being very driver friendly. At speed, the splitter works to create downforce, improving handling.
A raised central area provides ramp angle, providing needed clearance over steep driveways. It also improves the airflow to the horizontally mounted transmission cooler.
It also looks incredibly sexy, setting your 2016 2017 2018 Camaro apart and turning heads wherever you go.
The T7 Camaro Splitter offers the following features:
Improved frontal airflow management.
Manufactured in an OEM-validated RTM composite material.
Use of OEM mounting points for simple installation.
Installation is less than 15 minutes and is simple, utilizing the stock mounting bolts. Fits all 2016 2017 2018 Camaro I4 & V6 front fascias.
The optional winglets offer dramatically improved air flow and an great finishing touch. Over the last few decades, winglets have been used by both commercial and corporate jets. Jet designers have long known that airflow off the end of a wing caused drag. With the implementation of the winglet airflow is dramatically improved. Same principal applies to the latest Camaro Winglets / Deflectors line.
Both the splitter and optional winglets are offered in Primer finish or painted in Carbon Flash Metallic Black.
Application
2016 2017 2018 Camaro LT LS V6 and I4
PFYC is offline   Reply With Quote
Old 10-28-2022, 02:20 AM   #2
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/CO1023.html
