10-25-2010, 01:18 PM | #1 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
who has put just BMR trailing arms on and saw an improvement?
what was gained? did you have wheel hop before? i don't have wheel hop just some spinning.
10-25-2010, 01:48 PM | #2 |
took away all wheel hop, but increased spinning.
85 Buick TType - 5.3l GT4202r 10.86 at 126
10-25-2010, 02:59 PM | #3 |
Drives: '69 SS Convertible Join Date: May 2009
I used Spohn TAs but should be the same as BMR.
I had ton of wheel hop before. It all went away after TAs. I haven't had that much of spinning out of the stock Perellis but I'm only at about 410 rwhp and lowered tire pressure to about 25 psi. However, I haven't been getting my RPMs up well enough so my 60' and ET have been lacking. Once I start doing that then spin might be a factor.
Build Journal |
10-25-2010, 04:21 PM | #4 |
Drives: Race Car Join Date: Sep 2009
The trailing arms do an awesome job of getting rid of the wheel hop but it sounds like you are having a traction problem not a wheel hop problem. I would look into getting a better set of tires to start out with and then move on to the suspension/chassis modifications.
10-25-2010, 07:20 PM | #5 |
Drives: '18 5.7 RAM 1500 18' 1SS Join Date: Jun 2009
I'm in the same boat. When I hit 2nd I get slip/grab through the entire gear.
JRE Tune
11-07-2010, 11:00 PM | #6 |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
I haven't upgraded control arms but I have the Hotchkis Race Pack kit installed. No wheel hop but lots of spinning when I put down some power, I believe upgrading my control arms will help keep the vehicle straight when the rear sways left or right when I put down some power.
My next upgrade will be bushings. I believe if you don't have any suspension upgrades the control arms will help keep the rear straight, and will help with wheel hop too basically eliminates that wheel whobble to some degree, if you do some bushings I believe that will helps keep all the drivetrain, chassis frame, and diff from twisting which also assists with keeping wheels straight. Overall, the con is a stiffer drive (city roads have lot's of bumps, grooves and pot holes), but pro is the stifness provides a lot more control over the vehicle even if your wheels are spinning. I've invested in suspension, so I can drive without all the fancy TC / Stabili----, posi-traction whatever, and the vehicle feels great, and the control is awesome.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
11-08-2010, 02:45 AM | #7 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I have all the BMR stuff on Pumpkin. You can find me on a few different C5 fast lists.
11-08-2010, 06:40 AM | #8 |
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09 Join Date: Aug 2009
Tons of hop when I added nitrous. Arms took it away.
11-08-2010, 06:47 AM | #9 |
Used to hop pretty bad on a hard launch or dropping the hammer from a roll in 1st. Hasn't hopped on me once since I installed the rear trailing arms (BMR) and that's my only suspension mod as of now.
2012 - Present: 2011 CTS-V Sedan, A6, Airaid, Zmax TB and Tune by R.P.M. = 535 hp/503 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft. "Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree |
11-08-2010, 06:57 AM | #10 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
I run BMR TA's ...can't go wrong
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
11-08-2010, 08:41 AM | #11 |
Drives: RS Victory Red/BS V6 Join Date: Aug 2010
I plan on getting these now from all the great feed back, seem like a great tool to get rid of that dreaded wheel hop!
2010 Camaro 2LT RS M6 VR/BS Flowmaster AMT Axle Back Vararam Ram Air Intake P13 Plazma Bulbs DT Shorty Headers Heritage Grill Blacked-Out Taillights and Side Markers |
11-09-2010, 10:10 AM | #12 |
You honestly can't go wrong with our BMR trailing arms (TCA026) when it comes to getting rid opf wheel hop, they are quite inexpensive, are pretty easy to install, and can be installed with simple hand tools. When you are ready for a set give me a call and we can get you taken care of.
02-11-2011, 02:57 PM | #13 |
i wonder if the BMR trailing arms will help from spinning after you leave the starting line? my car seems to spin after the initial hook.
02-12-2011, 12:24 AM | #14 |
NuptualNemesis
Drives: Silver 1SS M6 - 480hp 11.57/120.79 Join Date: Jul 2009
.2 on 60 ft. already had Nitto 555 DR's.
Thread Tools | |
