07-31-2011, 12:03 PM | #1 |
Drives: Granite Crystal Challenger SRT Join Date: Jan 2010
CEL heeeeelp
I have a Vararam intake and the clamp that holds the maf sensor harness to the radiator hose got loose and contacted my power steering pulley.Two wires were damaged,I have made repairs to the wires but still have a CEL.The codes are P2534 and P069E,does any one have a clue as to what these are and how to correct it.
I have tried disconnecting the battery and still have them.Also car runs like crap.
07-31-2011, 12:36 PM | #2 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
Press your onstar button and ask them what does the code come back as and they will tell you. Post back and let us know what the code refers to.
07-31-2011, 12:56 PM | #3 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
codes will not clear just from disconnecting the battery,, you need a scan tool, also there is a 12v power wire in the maf harness, you may have blown the fuse that powers the maf (under hood fuse block, fuse #14, should be a 7.5 amp fuse)
07-31-2011, 01:05 PM | #4 | |
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT Join Date: Jun 2009
Code P069E means, Fuel pump control mdule requisted MIL illumination. Is this a V6 or V8.
Retired |
07-31-2011, 02:19 PM | #5 | |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
07-31-2011, 02:33 PM | #6 | |
Going to check fuse,thanks.
07-31-2011, 02:34 PM | #7 | |
V8-L99
07-31-2011, 02:45 PM | #8 |
Replaced fuse,cleared codes w/SCT scanner,CEL is gone.You guys are the greatest.
Thanks.
08-30-2011, 03:28 PM | #9 |
Drives: Black 99 Z28 Black '10 SS/RS Join Date: Jul 2009
I just had mine in the shop for those exact 2 codes. Turned out to be a short that blew a fuse.
It also caused a code for skip shift low voltage and caused the reverse lockout to lock me out of reverse. Warrantee took care of it and we're back, good as new!
99 Black Z28 '10 Black 2SS/RS on order 7/3/09, Delivered 9/21 |
Similar Threads | ||||
Long tube's and CEL | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 26 | 03-09-2011 08:17 PM |
Cure for the CEL ?! | 5thGENv6 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 27 | 02-12-2011 07:13 AM |
One possible solution to CEL P0430 w/ JBA midpipes | Goliath | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 01-10-2011 07:55 PM |
Another LT Headers and CEL for Emissions | kauffjd3 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 10-29-2010 02:54 PM |
Clearing a CEL | jtzako | 5th Gen Camaro SS LS LT General Discussions | 8 | 07-09-2010 01:37 PM |
