01-17-2018, 12:56 PM | #1 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
LSA dyno run for review & comments
Finally got my car back from the tuner and looking for thoughts on the results. This is new to me so don't know what to expect.
2010 L99 with 80k miles. ADM stage 1, ZL1 fuel pump, Speed Engineering Headers, modified CAI to fit supercharger. I did not install the ADM fpcm on the advice of the tuner. Results 437hp/442 ft-lbs at 7-8 psi. This is on a Mustang Dyno that he said a stock ZL1 hit 440hp max. I asked about the duty cycle of the injectors to see about room for future build and was told 90%. Thanks. |
01-17-2018, 12:58 PM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Something aint right, my l99 with all bolt ons was 421 if i remember correctly
Sent from my SM-N950U using Tapatalk |
01-17-2018, 12:59 PM | #3 |
Should have been closer to 480 to 550ish
01-17-2018, 01:25 PM | #4 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Looks about right to me on a Mustang. I believe the DynoJets present the 470-480whp results.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
01-17-2018, 03:42 PM | #5 |
'It's an experiment'
Was a baseline done on the same dyno?
-Don
747 RWHP 794 RWTQ
01-17-2018, 04:08 PM | #6 |
Unfortunately not. I hadn't decided on who I was going to get to tune it when I started the install. That would be my first recommendation to anyone looking at doing something this major. It would help eliminate doubt since I don't have first hand knowledge of any tuner. It seems to run good and stronger than before, of course not driving it for a couple of months could be part of that.
Should the boost be a minimum of 7psi and max of 8psi? My next step I guess is to get set up to data log. I currently have OBDwiz that will log some basic data (https://www.scantool.net/obdwiz/#Supported_PIDs) but I haven't used it yet. I may need to go beyond that anyway. |
01-17-2018, 04:48 PM | #7 |
Drives: 2011 L99 SS Join Date: Oct 2014
I don't know about one dyno vs another and the typical variances.
But my 2011 L99 dyno'd at 334 at ADM damn near stock. Andy installed the supercharger, headers, ZL1 fuel pump, FPCM and the rest of the stuff that goes in the stage 1, tuned & it dyno'd at 501/510. Last edited by nosmr2; 01-17-2018 at 04:49 PM. Reason: forgot words |
01-17-2018, 05:24 PM | #8 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Just got mine done last night, using a Dynojet. ADM stage II LSA (2.75 upper pulley). Stopped at 530/524. Tuner is the best in the area (NicD), and said the limiter was our 91 octane fuel. Pulled timing into the single digits. Happy with those numbers, though I thought 550-570 would be easy if I had regular access to 93. Hit the rev limiter on the way home, scared the shit out of me when the engine cut out for a sec. Thought I blew something!
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
01-17-2018, 05:37 PM | #9 |
At what boost level are people seeing over 500rwhp? I rather start seeing if I have a problem with my installation before I blame a possible problem on my tune.
01-17-2018, 05:45 PM | #10 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
what isn't right is why was the pull stopped at such a low RPM? should have gone to at least 6500...
01-17-2018, 06:40 PM | #11 |
01-17-2018, 06:50 PM | #12 |
Rpm stops when cam and eng stop making power, if it stops at 6k or 6200 then its no need to go past a 100rpm more max
01-17-2018, 07:26 PM | #13 |
I know it could be a stretch to just extend the graph at the same rate, but there isn't a turn down on the graph to indicate it had stopped making power.
01-17-2018, 07:36 PM | #14 |
Graph stops at 6k so it could very well be 6200 it stopped
