08-16-2022, 04:13 PM | #1 |
Drives: 2018 Chevy Camaro 1LT Join Date: Jul 2021
DRL Light dims when breaks applied
OK guys I thought I'd pick your brains on this one. I have aftermarket lights that include DRL's in the assembly. The DRL'S are hardwired to the fuse box. When I hit the BREAKS DURING THE DAY, The passenger headlights DRL's dims significantly when I release the break it goes back to normal. This doesn't effect the driver side which makes no sense because they are both hardwired together. Also why would the break pedal have anything to do with the headlights lol. I found out at night or when I block the light sensor on the camaro, the passenger side headlights drl doesn't dim and acts as normal. Everything else on both sets of headlights works as it should and there's no hyper flash issues. https://youtu.be/8wQpsQOvkVw
08-17-2022, 01:04 PM | #2 |
I'm going to guess a drop in voltage when the break is pressed but I don't know for sure.
08-21-2022, 06:34 AM | #3 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
I'll venture a guess you also have aftermarket brake lights in the rear, or did some LED "upgrades" elsewhere on the same circuit.
08-21-2022, 07:44 PM | #4 |
There are aftermarket tailights with the appropriate harness with resistors, they were made by a company online I forgot the name. Anyways its weird that it only affects the passenger side since both headlights are on the same fuse tap for DRL'S. At night they work like a dream during the day the passenger headlight DRL's dims when the break is hit. If I cover my hand over the camaro light sensor and hit the break the DRL's work fine. I did notice the headlight DRL's are very bright during the day but are dim at night due to the light sensor.
08-22-2022, 09:03 AM | #5 |
The DRL's might get variable voltage based on ambient light. I'll check the repair manual. Your aftermarket unit may not respond in the same way as the stock units.
08-22-2022, 12:57 PM | #6 |
Turns out it was aftermarket diffuser led lights, I unplugged them and now the headlights DRL's work as they should. I'm thinking adding that one extra thing to the circuit caused too much power draw and so the BCM dimmed the lights
08-22-2022, 01:37 PM | #7 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
The LED straw that broke the camel's back, heh.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
08-23-2022, 10:00 AM | #8 |
08-23-2022, 02:47 PM | #9 |
It wasn't flickering it dimmed when the break was pressed. They now work better than the stock headlights. There's absolutely nothing wrong with them, they're $1300 headlights with qaud beams and they get ALOT of compliments. Unfortunelty when upgrading things on a camaro the BCM and ECM are very sensitive so you have to do some troubleshooting to get them to run.
08-23-2022, 03:26 PM | #10 | |
08-24-2022, 09:16 AM | #11 | |
Most consumers expect these aftermarket units to be plug-and-play. Often they are not. I choose the easy route-- stick with stock. |
Tags |
aftermarket, headlights, morimoto |
