06-07-2014, 08:02 PM | #1 |
9.56@144.09
Drives: 2013 zl1 black Join Date: Mar 2013
1/4 mile
has any one tried starting out in second gear in the 1/4 mile. with first gear being so low and hard to get a good 60, time. this would be in the automatic trans zl1. I have mickey Thompson 305/45/18 inch street drag radials. I get 1.8s and the odd 1.7s in the 60 foot.
06-10-2014, 07:33 AM | #2 |
Drives: Camaro ZL1 Join Date: May 2012
How many lbs are you running in your tires at the track?
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
06-10-2014, 08:09 AM | #3 |
I have the same tires and an auto and pull 1.50-1.54 60's. I run my DRs at between 17-18 lbs. I do have a Yank 2600 stall torque convertor though. Plus other "stuff".
06-10-2014, 08:23 AM | #4 | |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
Sounds like those converters really work. Did you need to add extra transmission cooling for it? Who was able to tune it? I hear that is a big problem when doing a converter on a ZL1 |
06-10-2014, 08:53 AM | #5 |
Drives: none Join Date: Oct 2012
06-10-2014, 08:56 AM | #6 |
I'm pretty consistent lately. Last thurs out of 7 passes 5 had 60's in the 1.5s The converter works well. Matt from FSP really knows his stuff and has tweaked my tune a bunch to get it spot on. Of course I keep adding new things so I try to keep him busy. Another well respected tuner approached him at the track Thurs night as he was having issues with a CTS/V's trans tune. Matt tweaked it for him and they right away ran 2/10s quicker! I have not added an extra cooler and so far no issues. We did go with the triple disc Yank converter.
06-10-2014, 11:15 AM | #7 |
9.56@144.09
i am running 16lbs to 18lbs in the tires. sounds like it is hard to find a tuner that knows how to tune the trans in the zl1.
06-10-2014, 12:55 PM | #8 |
Car drives great on the highway. I'm driving From Venice FL to Toronto Ontario at the beginning of July. Idling along at around 55 it can lock and unlock a bit but nothing major. They do need some tuning by someone that knows what they are doing.
06-10-2014, 12:58 PM | #9 |
I'm not sure if Matt does remote tunes or not. I'll ask him when we go to the track on Sun.
06-11-2014, 04:11 AM | #10 |
06-11-2014, 07:21 AM | #11 |
06-11-2014, 09:21 AM | #12 |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
Do you leave off idle or do you stall it up a bit? If so, how much?
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
06-11-2014, 10:41 AM | #13 |
Depending on the track prep, but usually around 2,000 rpm.
06-11-2014, 11:29 AM | #14 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
60 ft is influenced by a complex stew..
- Track Prep - How your chassis works - How much power you make Where do you race, post a whole slip too.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
Thread Tools | |
