04-03-2011, 11:04 PM | #1 |
Pfadt Trailing Arms
Does anyone know if the Pfadt Trailing Arms eliminate wheel hop? It has been reported that the BMR trailing arms do, but I'd like to get the lighter Pfadt offering.
04-03-2011, 11:11 PM | #2 |
My car runs on acorns....
Drives: 2010 SS RS Inferno Orange Join Date: Feb 2010
They made a very noticeable difference in my car. I get very little wheel hop now. That was 530 at the wheels, already running pfadt sport 2 package.
04-03-2011, 11:13 PM | #3 |
04-03-2011, 11:25 PM | #4 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
You beat me to it, BigSquirrel. Yes, the Pfadt trailing arms do a very good job of eliminating wheel hop. Once you remove the OEM trailing arms, you'll be shaking your head at GM for putting in such puny pieces of junk in a 400HP rear wheel car.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
04-03-2011, 11:28 PM | #5 |
Zero wheel hop
550 RWHP |
04-04-2011, 12:50 AM | #6 |
I don't have as much hp as these guys but I have Pfadt and there are well worth it
Black cars are not hobbies, they are an obsession |
04-04-2011, 01:17 PM | #7 |
Thanks for all the feedback fellas, I ordered the Pfadt's this morning.
04-04-2011, 01:28 PM | #8 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Thanks for all the input gents. As mentioned earlier in the thread, wheel hop is certainly curtailed after the install of our Trailing Arms. We designed them to be both lighter and stronger than the stock pieces. The new design increases strength by 106%, reduces mass by 17%, and overall nets a 32% reduction in deflection.
What this directly translates too is less wheel hop due to the stock rear trailing arm deflecting under hard launches, or coming out of corners on power on the street or at the track. |
04-04-2011, 05:53 PM | #9 |
Drives: 2010 SS with WAY TOO MANY MODS Join Date: Sep 2010
04-04-2011, 06:21 PM | #10 |
Drives: 2010 2SS - Supercharged Join Date: Apr 2010
610 RWHP. Not gonna say it totally eliminated it but they make a huge difference. Totally worth it. I also went with the pfadt toe end links.
04-04-2011, 06:23 PM | #11 | |
Wheel hop is the direct result of excessive deflection in you suspension/chassis components and the soft stock bushings that causes toe changes and a decreased contact patch. By strengthening those components and upgrading the bushings you will kill the deflection and thus the wheel hop. A good set of trailing arms, like the sickness that Pfadt created, is definitely part of the equation.
04-04-2011, 07:06 PM | #12 |
Drives: 4 wheels Join Date: Mar 2009
04-04-2011, 08:39 PM | #13 | |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
The Pfadt instructions call for you to press the bushings in place. Really? Isn't this something that they should be doing from the factory? The BMR's come pressed in place. Would make the installation much quicker and easier, as I don't have a press. Guess you could do it in a vise?
Yeah, I'll get around to it...
04-05-2011, 10:49 AM | #14 | |
The stock bushing at the spindle on the other hand can be a little difficult. We can provide a tool that makes removal extremely easy. |
Similar Threads | ||||
Pfadt Race Engineering Rear Trailing Arms At Apex Motorsports!!! | Apex Motorsports | Suspension / Chassis / Brakes | 174 | 08-09-2012 05:43 AM |
Pfadt solid subframe mounts, diff bushings, sways and trailing arms installed! | AdamCzap | Suspension / Brakes / Chassis | 14 | 01-04-2011 05:54 PM |
Pfadt Coilovers Trailing Arms Install | tjd24 | Suspension / Brakes / Chassis | 11 | 08-09-2010 03:27 PM |
Looking for more traction? I recommend Pfadt Rear Trailing Arms! | Apex Motorsports | Suspension / Brakes / Chassis | 13 | 07-17-2010 05:29 PM |
Installed Pfadt rear trailing arms | BLACK67 | Canada | 6 | 07-11-2010 07:31 AM |
