04-06-2011, 08:12 PM | #1 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
BMR Trailing Arms work great!
I already had Eibach Springs/Sways installed for quite a while, but decided I wanted to add beefed up trailing arms and also added the adjusted toe rods from BMR. I've been driving a few days since adding these, and damn they help the hook up and make the ass end feel much more solid on take off. Now just need some new end links, maybe some braces and will be good to go.
04-07-2011, 08:55 AM | #2 | |
Drives: Race Car Join Date: Sep 2009
Kyle |
04-07-2011, 10:33 AM | #3 |
Mine would be alot better with some BMR rear lower control arms:emoticon7:
04-07-2011, 03:09 PM | #4 |
04-07-2011, 06:40 PM | #5 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
I installed the BMR trailing arms but still haven't really put them to the test. Only thing I worry about is that I got enough grease in the bushing. The instructions say to grease with the suspension under load. I was barely able to get the grease gun on the fitting. I gave it a bunch of pumps but didn't see any come out the seams of the bushing. It seems like they took some grease but how do you know it's enough?
04-07-2011, 07:26 PM | #6 | |
Drives: 2010 Camaro L99 Join Date: Oct 2009
04-07-2011, 07:36 PM | #7 |
Go Heels!!!
Drives: 2010 Camaro 2SS/RS Join Date: May 2010
Are you guys installing the optional outer bushing as well, or just going with the one that comes with the trailing arms?
Team L99
2010 Summit White 2SS/RS L99: TSP 1 7/8 LTs - Off-Road Pipes | Tuned By BLUECAT | CAI Cold Air Intake | ADM Race Scoop | SLP UD Pulley | VMAX Throttle Body | Magnaflow X-Pipe | Muffler Delete | SLP 160* T-Stat | MSD Wires |
04-07-2011, 08:23 PM | #8 |
I definitely recommend them. You are not really getting the full benefit if you reuse the stock bushing. Why they don't just include them is beyond me.
04-07-2011, 08:36 PM | #9 |
is spohn still the only ones with lower control arms?
THE "MENACE"
04-07-2011, 10:15 PM | #10 |
As of right now, yes, Spohn is your only option. But BMR keeps promising that theirs are coming soon (not sure what their definition of "soon" is)!!! And still waiting on the Drag Sway Bar and Delrin Subframe Bushings!!!
04-07-2011, 10:18 PM | #11 |
So Cal Race Team
Yes, I bought the bushings for the trailing arms too.
04-07-2011, 11:03 PM | #12 |
No bushings here, did not know at the time. But that was a great add on w/o the extra bushings! He is having the Cradle inserts end links and differential's going on next week, BMR's. He has the Trailing arms, toe rod's, and lower control arms, on the dropped position already. Bring that 60' down!!!
04-08-2011, 05:46 AM | #13 |
Drives: 2010 Transformer 1SS Camaro Join Date: Nov 2009
I changed the bushings with the Arms!
04-08-2011, 09:51 AM | #14 |
Like everyone else said we definitely recommend changing the outer trailing arm bushing when doing the trailing arm. You are already there and it is pretty easy to replace. As far as greasing the bushings go I grease them till I can see some grease coming out the side of the bushing or if the grease shoots back out the zerk fitting after pumping it in.
Similar Threads | ||||
Pfadt Trailing Arms | GrinderSS | Suspension / Brakes / Chassis | 22 | 04-18-2011 12:28 PM |
BMR Rear Trailing Arms, Tie Rods, Bushings, and More! | FREE Shipping!! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 19 | 11-13-2010 03:55 PM |
BMR Rear Trailing Arms | Robert@LateModelSpeed | Exterior Parts & Accessories | 0 | 05-03-2010 11:54 AM |
Spohn Tubular Rear Trailing Arms & Toe Links | SpohnPerformance | Suspension / Chassis / Brakes | 7 | 10-22-2009 02:17 PM |
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Polyurethane Bushing | LMPerformance | V8 Bolt-Ons & Tunes | 3 | 10-19-2009 03:33 PM |
