04-15-2011, 11:39 AM | #1 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
Is this an alignment issue?
the car is lowered 1". it was aligned at GM. the wear pattern or feathering is on both rear tires on the outside toward the fender lip.
04-15-2011, 11:40 AM | #2 |
this is what they look like when i get home from the track.
04-15-2011, 01:28 PM | #3 |
Banned
Drives: ... Join Date: Apr 2011
over inflated maybe also
04-15-2011, 02:45 PM | #4 |
Drives: 2010 Transformer 1SS Camaro Join Date: Nov 2009
Yeah too much air!
04-15-2011, 02:53 PM | #5 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
+1 too much air. You probably have to compensate for the expanded air pressure from racing. Friction that causes heat, warm air is less dense, expanding blah blah.. That or put some Nitrogen into the wheels =D I think that will reduce the expansion rate.
Alignment wear would be showing only on ONE of the sides, instead of the middle.
04-15-2011, 03:08 PM | #6 |
Drives: 2015 Chevrolet SS Join Date: Jul 2010
When you say "get home from the track" are you referring to autox or road course? If so, that "feathering" effect would be normal track wear and tear. In fact I would say it looks pretty minimal.
04-15-2011, 03:30 PM | #7 |
1/4 mile track is what he is refering to
my youtube
my facebook www.myspace.com/1djchampagne www.twitter.com/1djchampagne mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune 750/641 rwhp/rwtq |
04-15-2011, 03:37 PM | #8 |
He's not talking about the wear in the middle, he's talking about the rough edges that are appearing on the outside edges of the tires (as pictured). These are M&H Drag Radials, they are designed with the flat spot (no tread) in the middle.
I'm no expert, but I would think this is from too much positive camber, or maybe too much toe-in?? A good alignment would probably fix it. Maybe just take it to an alignment shop and first see if the alignment is off. |
04-18-2011, 01:10 PM | #9 |
Drives: 2010 1SS Join Date: Jan 2010
Do you have your alignment specs? The wear is certainly odd for the drag strip unless you are running a lot of positive camber. Typically IRS cars will wear the inside when the suspension compresses at launch and the tire sees negative camber coming out of the hole...
Similar Threads | ||||
Dealership Screw Up - Clearcoat Issue | FDNY-L107 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 04-26-2011 10:52 AM |
window indexing issue | TripleB | 5th Gen Camaro SS LS LT General Discussions | 9 | 03-20-2011 11:19 AM |
Sequential Tail Light Issue | 40again | Cosmetics and Lighting Modification Discussions | 5 | 03-17-2011 01:33 AM |
Lowering Alignment Issue | obe1 | Suspension / Brakes / Chassis | 38 | 03-05-2010 03:28 PM |
HVAC issue... Anyone had this problem? | nashstat | 5th Gen Camaro SS LS LT General Discussions | 8 | 01-27-2010 04:19 PM |
