06-21-2011, 09:40 AM | #1 |
Fast 65# ls3 injectors
Is it true these injectors are basically useless since they dont offer injector data charts with them?
85 Buick TType - 5.3l GT4202r 10.86 at 126
06-21-2011, 09:46 AM | #2 | |
Even with that they will never run as good as the Injector Dynamics, ID-850s. I experience it Daily. Ted.
www.jannettyracing.com
06-21-2011, 04:35 PM | #3 |
ya i understand that. I have a customer that brought me these for his maggie and cam 2010 Camaro. We just installed the lingenfelter twin pumps kit and am unsure if i should put these in or if i should just see if the stock maggie ls9 injectors will be enuf.
06-21-2011, 08:55 PM | #4 |
LS9 injectors will support it, but they'll be maxed out. The FAST injectors will never function as good as injectors that have had true characterization done.
06-22-2011, 12:19 AM | #5 |
I wasn't sure if LS9 injectors will support 600whp...which is probably right around where this car will be. Thanks for your help DSX. I think your the one helping me on hptuners as well.
06-22-2011, 01:29 AM | #6 |
Yes, that's me. They won't go up to 600whp. I usually see them run out at 500whp on return style fuel systems.
You can jack the fuel pressure way down at low demands by copying the FPCM settings from a CTS-V, but that's a cheap trick to get around the issue, and they still don't have the correct voltage offsets to work perfectly clean. |
06-22-2011, 07:46 PM | #7 |
ls9 injectors are at 100% at 6k rpm. ted do u have any data that i could use. I'm sending you a pm.
06-22-2011, 08:20 PM | #8 |
Booooosted.
What does a TVS2300 come stock with?
06-22-2011, 08:24 PM | #9 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
06-22-2011, 08:25 PM | #10 |
Booooosted.
06-22-2011, 09:05 PM | #11 |
52# at what fuel pressure?
The FAST 65s are rated at 4 bar.
06-22-2011, 09:06 PM | #12 | |
I have run them to a little over 600 RWHP on LS3 with 58 PSI to redline with an MSD Voltage booster. Email is Best.
06-22-2011, 09:09 PM | #13 |
Booooosted.
I was asking because adding my cam to my SCed build I was thinking I needed bigger injectors.
06-22-2011, 10:02 PM | #14 |
ls9 are 52# @ 58psi and come in the maggie kits
Similar Threads | ||||
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
FAST 102 MANIFOLD LS3 | boat rx | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 12-20-2010 10:58 AM |
WTB: LS3 intake manifold with fuel rails and injectors | G_Loc | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 6 | 10-13-2010 08:21 AM |
FAST 102mm LS3 Intake Manifold $825 SHIPPED!!! | Rich D | V8 Bolt-Ons & Tunes | 0 | 11-19-2009 10:14 AM |
