Old 03-29-2013, 01:49 PM   #1
Wolty
Drives: 2012 ZL1
Did I Miss Something?
From what I recall and have read about the ZL1 and Z-28...in the sixties/early seventies version of the Z28 was the smooth ride super fast camaro...you could get auto, AC, and the up-scaled RS package with the Z28. On the other hand the ZL1 was the bare bones stripped down version with the 427...a drag car.
Am I missing something or did GM get it backwards with the current Z28 (bare bones drag car with the 427) vs ZL1 (super fast smooth ride, LSA...not a 427)???
Wolty is offline   Reply With Quote
Old 03-29-2013, 01:52 PM   #2
The Baron
The Baron's Avatar
Drives: 2013 zl1
Lol the new z28 in NOT a drag car.. it was built strictly for road racing.
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
Old 03-29-2013, 01:56 PM   #3
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Wasn't the original Z/28 in the late 60s built specifically for Trans Am racing? It was Chevy's answer to the Boss 302.
And the new Z/28 is not a drag racer. It will probably run circles around the ZL1 on a road course.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 03-29-2013, 02:42 PM   #4
ZEDL1
Drives: 2013 ZL1 Triple Black, 2015 2LT/RS
Good observation. Yes it was, and the need for a below-305 CID engine (per the then-existing rules) is what created the venerable 302 for the first 3 years of Z/28 production in the /60s. Those rules were changed in 1970, resulting in the larger 350 LT-1 being the engine installed in the Z's of that year and forward.
That said, I agree that the 2014 Z/28 is built exactly as was originally intended for the first /67 - /69 model years - road track racing. Great call for GM/Chevrolet this return to those roots.
The (slight) anomoly is in fact our ZL1s, since the one-year-only /69 Zl-1 was built to command the drag strips. Something that it did quite well, in its' day. Our ZL1s do everything very well, but are not intended to be dragstrip-specific, as it seems was the GT500.
I too am interested in seeing how a /14 Z/28 compares with a ZL1 on a road course. I don't care about the end result, as I have the car that I want, but I'm still curious...
ZEDL1 is offline   Reply With Quote
Old 03-29-2013, 02:53 PM   #5
GoldenBear
Bear Backer
GoldenBear's Avatar
Drives: 69 Camaro Z/28, 69 Corvette Conv
First generation Z/28's were not available with automatic transmissions or A/C. An automatic transmission was not available in the Z/28 until 1970. A/C was not available on the Z/28 until 1973.
Yes, the original first generation Z/28 was built to compete in SCCA Trans-Am racing.
You have it backwards. The Boss 302, first introduced in the 1969 model year, was Ford's answer to the Z/28, first introduced in the 1967 model year. The Z/28 won the SCCA Trans-Am class in both 1968 and 1969.
Current Chevrolets: 1969 Camaro Z/28 -- 1969 427/390 Corvette Convertible -- 1970 350/300 Corvette Convertible -- 2013 Camaro ZL1 Convertible -- CRT / Exposed CF Weave Hood Insert / Suede Package / Polished Wheels / MN6
GoldenBear is offline   Reply With Quote
Old 03-29-2013, 03:18 PM   #6
jazznurse
jazznurse's Avatar
Drives: 2012 ZL1;2011 Cruze
I seriously doubt if the new Z/28 will "run circles around" the ZL1. It's only 300 lbs lighter. Most of the technology it uses is from the ZL1. Maybe the should be marketing it as a "ZL1 Light". And the same people who cried to have the ZL1 available as an automatic will scream for the Z/28 to have one as well. Some people are never happy. Personally, I am. I have my ZL1, and it's all the car I'll ever want, or need, and I am NEVER getting rid of it. I look forward to running a road course againt some of my Z/28 brethren. Either, way, the winner is A CHEVY CAMARO!
jazznurse is offline   Reply With Quote
Old 03-29-2013, 03:36 PM   #7
hognutz
hognutz's Avatar
Drives: 2013 ZL1
It proabably will run circles around it stock vs stock. ti will proabably flog the ZL1 like the ZL1 flogs the 1le.
here is why
1. 300LBS lighter 68lbs of that being unsrpung wieght this has more advantage than just weight
2. carbon cermaic brakes there are like 8-10k brakes (this are the best brakes out there)
3. no heat issues do to being N/A.
4. little less torque be easier to mange corner exit most likely and then lower gear and high revs fro the straits.
5. no frills suspentions tuned for the track.
now all that being said the ZL1 is a 1G car and for all the crap people talk on the internet no novice weekend shoe get the full drive out of a 1G car like a pro very easy.
add pulley, cai, tune, hx to a ZL1 and that 3 second advantage might be gone and still have all the creature comforts.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 03-30-2013, 12:32 AM   #8
flyingskibiker
flyingskibiker's Avatar
Drives: Cars, Trucks, Bikes, ORVs, Planes
Send a message via Yahoo to flyingskibiker
The first gen Z/28 was not a 90% track car like the 2014. Basically, besides the engine and tires/wheels of the '67-9 Z28 RPO (it did consist of more than that), one could order the same car with a 350 in it... Just check the SS-350 box on the order form and get the 12-bolt. Add M21, HD suspension and front disc brakes, plus a few other bits and pieces, and you were on par with the track performance of the production Z/28. One could argue that the 302 could wind up and had more horsepower than was on paper. I would think checking another box on the SS order form to change rear gears and it would most likely make it right back up.
Once a buyer checked the Z28 box on the order form, they didn't have to stop. They could add radio (no first gen came with a radio by default), RS, power anything, console, gauges, etc. etc. The only things they couldn't check were convertible (but you could get a vinyl top!), A/C, and automatic. So, it wasn't a track car any more than an SS was a strip car. Yes, one could buy it and take it to the track. But it was a STREET car first... It was never stripped down. OK, in '67-9 there wasn't much to begin with, but...
Don't get me wrong, I would own the 2014 if I could afford a track car. It is SUHWEET! Though, I think it is more a tribute to the Camaro's racing heritage than a first gen production Z/28.
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it...
Drooling over the ZL1s. It will be my next car if I can manage to pull it off...
flyingskibiker is offline   Reply With Quote
Old 03-30-2013, 01:52 AM   #9
fielderLS3
fielderLS3's Avatar
Yes, you are right. What I meant to say was that they were direct competitors, built for the same purpose. The first Z/28 came after the earlier Ford/Shelby Mustangs, and before the later Boss. The Ford people would like to forget their effort between the two.
Old 03-30-2013, 04:33 PM   #10
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
Are you sure you could not get a/c in a Z28 until the year of 73? I grew up in the "muscle car era" and I really believe a guy I knew had a/c on his red 1970 Z28. I maybe wrong and I am old as dirt now but I could have sworn he did!
Bigtime53 is offline   Reply With Quote
Old 03-30-2013, 04:52 PM   #11
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
Most likely dealer installed.....
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 03-30-2013, 07:39 PM   #12
Wolty
Drives: 2012 ZL1
Whether the z/28 was a drag car or a Trans Am series racer was not my main point...I was mainly pointing out the fact that why does the Z/28 have the 427 instead of the ZL1 as it did in 1969?
Old 03-30-2013, 07:44 PM   #13
tones2SS
tones2SS's Avatar
If the 2014 Z28 does win,....it won't be by much in my opinion. Granted the Z28 is lighter to compensate for having less horsepower, but the ZL1 was made for the road course. Especially that suspension. Just my opinion.
Old 03-30-2013, 08:09 PM   #14
68vert
68vert's Avatar
Drives: 2010 SIM SS/RS, 1968 RS convertible
They have said the Z/28 beats the ZL1 by about 3 sec. They didnt mention th e track, but assume one of GM's own proving tracks.
Also, the new tires on the Z/28 are suuuuper soft and sticky. Treadwear is like 60 or 80.
2010 SIM SS/RS see garage for mods
68vert is offline   Reply With Quote
